09-16-2012, 02:07 PM | #1 |
76 GMC Camper Special 350 4 barrel
I found a 76 Camper Special with 58,000. Completely stock, the glove box sheet says it has the m40 turbo. I thought it would be a 400 but have been told it would be a 350 turbo. Was considering a crate 383 or 502 high torque. Would the 350 turbo be enough for the 383? Cruising at highway speeds, would the 383 get just a couple of miles per gallon more or would there be a huge difference? Haven't been able to determine my differential ratio yet. How does everyone like the 502HT?
09-16-2012, 06:50 PM | #2 |
Re: 76 GMC Camper Special 350 4 barrel
M40 is the turbo 400. Yes, a th350 can be built to handle good power, put if you plan on doing heavy towing with a lot of power, then I would use the 400 with a good tranny cooler.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
09-16-2012, 08:27 PM | #3 |
Easy to tell what you have!
Vacuum modulator points to the rear on a T350 and to the side on a T400. |
09-16-2012, 08:42 PM | #4 |
I really like my 502HT. I had considered rebuilding the original 454 to a 496 and doing it the way I want, but lack of a decent machine shop nearby had me lean towards the crate engine for the same price.
I primarily use my truck for towing hence the reason for a cubic inch increase. The 502HT performs better than I thought it would. |
09-16-2012, 09:10 PM | #5 |
Brought the truck home and it has the turbo 350. Surprised an 8200lb gvw has a 350 but maybe that was a common match with the 350 motor.
09-16-2012, 11:13 PM | #6 | |
350 engines got the lesser trans. |
09-16-2012, 09:35 PM | #7 |
Moderator
SPID tells what it left the factory with. The M40 TH400 was replaced in the last 36 years. The TH350 was cheaper to buy used so it's not surprising.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
09-16-2012, 09:55 PM | #8 |
Just found several posts in chevytalk saying m40 up to 1976 in 3/4 and lighter meant HD trans and they were TH350.
http://www.chevytalk.org/fusionbb/sh...4/pid/1761165/ |
09-16-2012, 09:58 PM | #9 |
Guess I can't link like that. Several people commented that their 3/4 m40 was a TH350.
09-17-2012, 12:49 AM | #10 |
Moderator
http://gmpartswiki.com/getpage?pageid=55577
M38 = THREE SPEED AUTOMATIC 11.75" TORQUE CONVERTOR Chevrolet built M40 = TH400 Your SPID lists M40 so it had a TH400. Look next to the gas pedal for the TH400 kickdown switch.
And please let us know if and how your repairs were successful. Last edited by hatzie; 09-17-2012 at 12:59 AM. |
09-17-2012, 01:58 AM | #11 |
No kickdown switch. I know the original owner. 58,000 miles. No work done on transmission. Thanks for the great link. The link to chevy talk is now good. What do you make of their conversation? |
09-17-2012, 12:08 PM | #12 | |
09-18-2012, 12:47 PM | #13 | |
Moderator
My link is to the appropriate RPO page in the 1973-1979 GM Light Truck parts book. If the TH400 & TH350 were both Production Option M40 I would expect a notation in the parts manual about this caveat. It's possible that GM used the M40 RPO for TH350 auto till 1976. It's also possible that the SPID was screwed up or the line was short the TH400, so, the TH350 was subbed in for some trucks. 100% speculation without talking to someone who was there. It would be interesting to compare broadcast sheets to the SPID label. My 76 K20 Camper Special originally had the TH350/NP203 with a 350. The SPID was missing but the broadcast sheet jammed in the seat springs called out M38.
And please let us know if and how your repairs were successful. Last edited by hatzie; 09-18-2012 at 12:53 PM. |
09-17-2012, 03:59 AM | #14 |
I have a 76 GMC camper special (10000 GVW) with a 467 ci BB and a turbo 475 out of a motorhome. I dig it.
Posted via Mobile Device |
