TILT COLUMN GURU
![]() Join Date: Dec 2006
Part search help
Hi all, I am working on a 81 silverado 305. I was looking for a oil pressure switch that controls electric choke. My question is, Is that part available or is it reproduced?
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
Happy to be here
![]() Join Date: Mar 2000
Re: Part search help
Anyone got a part number?
In the Forgotten far North.
![]() Join Date: Jul 2007
This might help from NAPA's website. I lookedit up for an '81 C10 with a 5.0L/305c.i.d. engine.
It's located just under the distributor and to the D/S at the back of the block sometimes screwed straight into the block or with the use of a 45* - 90* elbow. Oil Pressure Light Switch Part # OP6624 Source; NAPA AUTO PARTS Features & Benefits; Light Type, Also Used As Electric Choke Heater And Electric Fuel Pump Pressure Switch.; NAPA Echlin Products Meet Or Exceed Original Equipment Specifications. All Products Are Top-Of-The-Line Quality, & 100% Tested & Inspected In An Environment That Is IS09000 Compliant. Attributes; Oil Pressure Switch Pressure Rating : 2-7.5 psi Oil Pressure Switch Thread Size : 1/8" x 27 NPTF ![]() Oil Pressure Switch Connector Part # EC48 ![]() ![]()
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 09-21-2012 at 11:17 PM. |
You can bypass that switch if you prefer. Just be aware that the choke will be heated from the moment you turn the key on. If you tend to not have your key on when the engine is not running it shouldn't be an issue in cold weather.
Alex. |
