Old 09-23-2012, 09:21 AM   #1
hardhead
72 proportioning valve
I know this should go under the brake forum but I'm not getting any response over there. I have a proportioning valve from a 72 and it doesn't have a button to re-center the shuttle valve in it, it just has a plug in the end. Anyone had a problem with one of these? how do you re-center it?
hardhead is offline   Reply With Quote
Old 09-23-2012, 09:57 AM   #2
sjarrett71
sjarrett71's Avatar
Re: 72 proportioning valve
Remove the plug. The button should be under it. To recenter mine, I just stomped on the brake peddle a few times until it "popped" back into place.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 09-23-2012, 10:07 AM   #3
geezer#99
geezer#99's Avatar
I found this. Did you do a search?
http://67-72chevytrucks.com/vboard/s...d.php?t=336053
Old 09-24-2012, 09:34 AM   #4
hardhead
Tried all that and installed another valve. I think the new MC is bad on the front side. Going to replace it today and see if it fixes the problem.
Old 09-24-2012, 09:43 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Do you have any pics of your M/C set up?
Keith
Convert to disc brakes.
Old 09-24-2012, 12:50 PM   #6
hardhead
Don't have a pic, I'm at work right now.
Old 09-24-2012, 01:11 PM   #7
davepl
davepl's Avatar
Hmm... I have the same valve, though brand new, since I'm converting over to '72 discs. I was not aware there was any magic in terms of setting these up, I thought you just plumbed them and bled them.
I'm guessing there is a shuttle valve that can stuck to one end and cause problems, but beyond that I have no idea.
Would someone be so kind as to tell me what it is that I don't know? I'll refer to the shop manual when the time comes, but helps if I know in a general sense what's going on.
Sort of like finding out one day that there are muffler springs and you had no idea!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-25-2012, 12:10 PM   #8
hardhead
The proportioning valve has a centering valve I believe it is called. This valve is in case you severe a brake line or blow out something the pressure from the good side of the brake system will force it in the opposite direction to cover the port on the low pressure, or blown out side so you still have some brakes. I have never had this issue while bleeding a brake system before but until the system is bled and the pressure is equal on each side there is the possibility of this happening. There is a tool designed to go in place of the brake switch while bleeding to prevent this from happening, I found a picture of one on the net. I seem to have it fixed, not sure what it was changed the MC and cleaned the prop valve.
