![]() Join Date: Sep 2012
Has anyone converted a 2 wheel drive to 4x4?
has anyone converted a 2 wheel drive to 4x4? If so did you use the original 2 wheel frame or find a donor? I dont like the look of putting on a newer frame but can find a 4x4 shortbed frame bought one today but mainly for the shackles since it had a hole rusted into frame and it had been shorted from a long bed not sure what i want to do now since cant find a frame that i need. any ideas??
Re: Has anyone converted a 2 wheel drive to 4x4?
1 on e-bay right now
what is it listed under?? I tried to find it and i cant find it is it just a frame?
1961 crewcab
I am in the process of converting my sub over (check the build threadV), using 88 sub 4x4 parts
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
I'm converting my 63 check to 4x4. I have a build thread in the 4x4 project forum. It might be a few pages back because u haven't posted/worked on the truck in a while.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
