I have a 69 C10, 3 on the tree. Occasionally, whether downshifting or upshifting, my linkage will lockup (naturally only at a stop with vehicles behind me), and I have to turn off the engine, get out, raise the hood and pull up one of the 2 linkages on the column. If I'm attentive to shifting, I can go months without this happening, but, sometimes I just want to shift without babying it. It's always been a little stiff going from gear to gear, but, I think this is not normal, duh. And there should be a procedure for adjusting this, right?
Active Member
![]() Join Date: Jul 2007
Re: My 69 C10 shift linkage locks up sometimes
First thing you need to do us make sure the linkages have the rubber bushings on them -both top and bottom at the trans linkages. Then you need to adjust them properly.
Check this writeup to see if it helps.. http://67-72chevytrucks.com/vboard/s...d.php?t=215307
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Looks like the bushings are there, but wobbly. The link is excellent, thanks, I'll be able to fix it from that.
CAN'T FIX NOTHIN
I learned to drive on a 69 c10 3 on the tree , I have never had problem ? My 67 shifts perfect for me but if anybody else drives it it hangs up ? I let my girlfriend drive my truck in the lowes parking lot she made it about 40 feet and hanged up the gears lol , you may need to practice you may not actually have anything wrong mechanically
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Tags |
linkage, locks up, shift |
