09-24-2012, 12:49 PM | #1 |
67, remove tuneport install 5.3
Got a new project at the shop . It's a nice 67 with a camaro tuneport that has a pretty bad wiring install. So I'm removing and replacing with a 5.3 .
The motor when I got it home. Motor washed up getting ready for paint Removed all unwanted wiring from harness getting ready to rerout for a cleaner look exiting behind the intake Posted via Mobile Device |
09-24-2012, 01:53 PM | #2 |
67cheby
Re: 67, remove tuneport install 5.3
great looking truck
09-27-2012, 09:28 PM | #3 |
looks good
09-27-2012, 09:29 PM | #4 |
Need to lower it more!!!!!
09-29-2012, 08:11 PM | #5 |
Got some work do today
Took a while to get the mounts to work with stock a/c. Had to notch the compressor bracket in order to move the mounts forward enough to clear the headers. Eventually I got everything bolted up and marked the frame for some small clearance issues. I then removed everything to focus on engine bay cleanup before final install. Then on to some major wiring issues Posted via Mobile Device |
09-30-2012, 05:46 PM | #6 |
Looking good. How do you like that column? I was kind of thinking of going that route if it wasn't too much trouble.
10-01-2012, 08:54 AM | #7 |
I don't know bout the column. I have driven the truck about 30 yards into my shop. It's noty truck I'm doin the swap for someone. He's a new member here name is parker086.
10-06-2012, 10:54 AM | #8 |
Pic from when I was getting engine bay ready for paint. It's painted now just don't have a picture yet. Motor should be going back in tonight for final install and wiring.
10-11-2012, 08:22 AM | #9 |
Good gracious that is a lot of wiring in the dash.
10-13-2012, 08:26 PM | #10 |
Getting close just need to button up few loose ends but you know how that is, forgot this forgot that.
Wiring routed into cab behind cluster where PCM relays and fuse block are located. The view from my shop tonight. Had to take some time from wiring and put a cam in my truck. Posted via Mobile Device |
10-14-2012, 01:50 PM | #11 |
1 thing at a time is progress.
Lookin' great Dan!! I'm tuned in.
Alan
Philippians 2:14-16 |
12-04-2012, 10:36 PM | #12 |
Very cool progress and an awesome install. I'm putting a LQ4 in a '72. Any chance you have pictures of the modified a/c bracket? Any pics of the driver side header clearancing? Are those stock v8 engine towers?
