09-26-2012, 10:51 AM | #1 |
6x9's in the door - Yes Or No??
Please post some pics of your door speakers and kick panels. I have the LMC kick panels but the emergency brake is in the way.
Thanks! HB
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
09-26-2012, 11:25 AM | #2 |
Re: 6x9's in the door - Yes Or No??
I say no, if you are going to cut 6x9 holes in the door. In the past I have made, as well as purchased, 6x9 speaker enclosures and attached them to the bottom of the door. They did not interfere with my feet and four small screw holes was better than one big 6x9. For my current project I moved the gas tank to the rear and purchased some behind the seat enclosures from a board member that builds them.
Several guys here have the LMC kick panels as well as home made/custom enclosures. I don't remember any complaints about the E-brake. There may be some adjustments you can make. I don't know if you can do this or not (columns may be different, etc.), you may consider converting it to the 67/68 hand E-brake. This is all food for thought. I'm sure you will come up with a good idea to get those big speakers in there.
1968 Chevy C/10 LWB V8 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
09-26-2012, 11:35 AM | #3 |
I also say no I put my 6x9's in the rear corners and I have the kickpanels but i made my own so it can clear the e-brake, in the rear corners the truck had the metal brackets for 5x7's i think? well anyways i took those out and just made a new one to fit a 6x9 out of wood painted it black and screwed it in and it sounds good!
09-26-2012, 11:51 AM | #4 |
Roll the window down, prop your arm out and just listen to the truck. I wouldn't mind if my truck didn't have a radio really. My GMC has one but it doesn't work. It's on the bottom of my list to get it working. No way I'd cut my doors. Just my opinion. I'd say No.
Is the tank in the cab? There is a guy on the forums that sells custom speaker enclosures for the back corners of the cab (if that's an option)
09-27-2012, 11:30 AM | #5 | |
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
09-26-2012, 12:06 PM | #6 |
I got my truck with them already in place in the doors. I wouldn't have done it personally. I would have done the kick panels, and 6x9's in the corners behind the seat. There is a member that sells the metal 6x9 bracket for the corners of the cab. There is also a member that sells the kick panels that clear the emergency brake. There are several options, have fun choosing.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
09-26-2012, 12:08 PM | #7 |
Looks like NO is the answer. I'm gonna try CC69RAT's way and lean out the window a little more and leave the stereo as is for now. Tank will come out next year and then I can throw some 6 x 9's in the back.
Peace and chicken grease!!! Thanks for the feed back fellas'!!
09-26-2012, 05:34 PM | #8 |
Cruzin
i just build a couple boxes and put them under the seat, and added two 3 1/2 in the center under the dash where the factory speaker was. I welded the hole in the door up darn PO got to fix the radio hole back to factory look also.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
09-26-2012, 05:48 PM | #9 |
Here is a visual "why not". The rest of the truck was pretty much the same level of "improvement". To me door speakers knock about $500.00 off the value of a truck with otherwise, good servicable doors.
Hey this just gave me a good idea..... research time :-)
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
09-26-2012, 06:28 PM | #10 |
Moderator
grab ahold of your e brake pedal, pull on it sideways, and bend it out a bit. it will clear the speaker panel. oh, and dont cut your doors!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-26-2012, 09:25 PM | #11 |
I don't know what the big deal is about putting speakers in the doors. I'm one of those guys who cut the doors you guys are griping about. Been doing it for decades. It's the best place for them. If GM offered stereos back then,that's where they would have put them. That's where they put them in many newer models. If you decide you don't want good sounding music you can always patch the doors easily enough. I just don't get the big deal,with all the other alterations many are doing. At least this one serves a purpose.
09-28-2012, 11:32 AM | #12 | |
Happy to be here
The speakers found in many of the current cars/trucks are not mounted that low, and are usually part of an integrated speaker system. Throwing a set of 6x9's in a hole near your feet is a horrible location.
09-28-2012, 01:04 PM | #13 |
An option:
Bucket is molded fiberglass sandwiched between two foam bowls. Fenders must be off, will cut thru small section of cowl vent, that must be resealed. sealed with seam sealer. There will be carpet kick panel added later. The only way that I could find to clear parking break.
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ |
09-28-2012, 01:04 PM | #14 |
09-28-2012, 06:22 PM | #15 |
LS1Nova71: those doors look so good it makes me want to cut mine! And I don't even have a radio!. Seriously, they look good.
Posted via Mobile Device |
09-26-2012, 09:30 PM | #16 |
My doors will get cut as well as the dash, is what it is and that's mine..lol
09-26-2012, 09:41 PM | #17 |
Different people will always have different input / opinions and priorities. Their truck usually has purpose in their life, and they want certain things from it. Me, I like a good sounding truck with snappy throttle response that handles like its on rails. Sometimes that means modifications that others wouldnt do.. Im cool with that.
Some like stock 4x4s .. good sounding radio / stereos, LS conversions, all require modifications. If the stereo is your priority, cut the doors.. no worries.. Im just not really a stereo person. However I do like em low and big billets. Just sayin.. thats just me. Posted via Mobile Device
09-26-2012, 09:44 PM | #18 |
No. I put some box speakers under the seat facing the firewall and they sound nice.
MusicMan70 1961 GMC Suburban |
09-26-2012, 09:48 PM | #19 |
Not to hijack, but do you need something to protect the speaker from water that gets inside the door?
'69 Fleet It ain't yours, if you didn't build it! |
09-26-2012, 10:01 PM | #20 |
BlahBlahBlah
Personally I don't care if the doors are cut for speakers. You can insulate the door with some sort of sound deadener. You can put some type of water proof over them if you are worried about moisture. And with a little bit of imagination and effort you can make em look fine.
When you look at giant holes in beat up doors of course that's gonna make you wonder if its a good idea.
09-26-2012, 10:05 PM | #21 |
My doors are already cut for 6" x 9"s, I was just wondering if they make a cover for the back of the speaker?
Thanx in advance, Dano
09-26-2012, 10:12 PM | #22 |
Its a personal choice. The only issue I see is you can't undo the holes cut in ones door.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-26-2012, 10:25 PM | #23 | |
The holes from speakers can be repaired just like any other patch in the sheet metal. There are even inner door bottoms made.
09-26-2012, 10:33 PM | #24 | |
Unless you had to have someone to do the repair work it might get a some $$$ into it...but as you said it could be patched up.
09-27-2012, 12:37 PM | #25 | |
English Chevy Owner
http://www.crutchfield.com/p_237XT69...th.html?tp=660
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
