BB A/C belt problem
My A/C belt wore a hole in the lower radiator hose. Truck is a '72 2wd. Blazer, fact. A/C with a mild 454. I've driven it (HARD) for a year w/no problem but apparently when I started using the A/C the belt whipped a little a rubbed the hose. The belt rubs right on the bulge in the hose at the water pump outlet. I made a little stainless shield to protect the hose but there's NO clearance. ANYBODY have this problem? I have an aluminum water pump and crank pulley.. all the pulleys line up good. Don't see many things to adjust to fix this
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
Re: BB A/C belt problem
i am having problems finding brackets to fit my weiand aluminum water pump made in china,i am taking it off,no problem with the old chrome pump.i have a 509in my truck.
#3 | |
I'm a saver. On my 1971 Monte it looks like GM put a little plastic guard on the lower hose for the same issue. I simply re-purposed that guard on my truck. Next time you're in a junk yard, look around for a similar piece. Another option would be to take your now bad hose, cut off about a 3 inch piece, and slit it open. That then can be positioned over the lower hose where the belt hits. I've seen that done a million times on vehicles of this vintage.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#4 | |
Always on the hunt...
![]() Join Date: Sep 2006
Thanks for the replies..
Mel, GOOD INFO!!. I'll see if I can swap the order of the belts. If it works I'll be FOREVER INDEBTED.
