10-02-2012, 01:49 PM | #1 |
Suburban Fuel Tank Transplant
Looking for information on transplanting a 30 gal Suburban tank into a shortbed pickup? Did a search, but didn’t find what I was looking for.
10-02-2012, 09:21 PM | #2 |
Re: Suburban Fuel Tank Transplant
This sounds interesting, mine is a LOOONG bed but I would love a 30 gallon tank. If I may ask what year/model suburban did they come in?
01-05-2013, 08:50 PM | #3 |
www.73-87chevytrucks.com
I assume you mean the 28 gallon tank this is the write-up I did:
http://www.captkaoscustoms.com/blazertank.html Posted via Mobile Device
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-05-2013, 10:30 PM | #4 |
Nice any pics of how the fuel filler was ran? Or all finished with bed on it?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-09-2013, 02:22 PM | #5 |
Never got any finished pics from this one, but I am finishing up my 1987 R10 Conversion truck on my forum and it has the same setup, there will be pics of it when it is completed.
01-09-2013, 07:34 PM | #6 |
GoatLube Experss
Suburban tank is next on my list, I'm curious if it could be mount'd side way's so the filler is piont'd to the rear. my bed floor is raise'd 7.5" and I want the fill cap behind the tailgate.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
01-10-2013, 02:31 PM | #7 |
I have the blazer tank on my truck, but i mounted it from the top of the frame for extra ground clearance. i think you could make it work with it sideways, but all the hoses and stuff would be clocked facing towards the rear too.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
01-09-2013, 07:44 PM | #8 |
Wasn't there a big tank option? My blazer has a 31 gal tank listed on the spid
01-10-2013, 01:02 AM | #9 |
Here are the options and measurements for the squarebody Blazer/suburban tank. I'm looking at doing the same thing to replace my fuel cell. My gas filler is behind the tailgate as well and I need the filler to aim back. I have checked around and most salvage yards have the tanks for around $100.
http://www.lmctruck.com/icatalog/CSB/full.aspx?page=143 |
01-10-2013, 02:13 AM | #10 |
I'm putting in this 31 gallon Blazer tank in my 81 C-10 longbed in place of the 16 gallon fuel cell I have in there now. Still trying to work out new mounting brackets though.
01-10-2013, 03:46 PM | #11 |
I found the big issue for me on this was the fuel fill dilemma. At first I thought I could run the fuel fill to the rear and do a flip up license plate deal, but it won't work because the bumper is lower than the top of the tank.
I wasn't willing to weld in a new fuel door on the side of the bed and I didn't want to put it in the bed floor. The taillight trick is cool, but way beyond my fabrication skill level. |
01-17-2013, 11:36 PM | #12 |
I was kind of figuring on cutting in the filler door in a Blazer like location behind the wheel. Filler doors are ugly yes, but it seemed like it would be fairly simple.
01-10-2013, 04:25 PM | #13 |
It is too long rotate to the side. The tank is aready close to the pumpkin in the normal rotation. Turning it around is going to be an issue as you would still have to cut your bed sill if you want to aim it back, or if you aimed it up you have to notch the bed sill. The way it is ran is the best option.
On this one it was ran to the side and turned up in the corner of the floor...
01-12-2013, 02:49 PM | #14 |
I want to make my driver side tailight flip open, for a filler neck. anyone done that before? think it would be sweet for the rear tank.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
01-20-2013, 09:10 PM | #15 | |
GoatLube Experss
for the filler cap I want to run it the new filler panel that will be between the floor and the botom of the gate.
01-17-2013, 11:16 PM | #16 |
There is a write-up of the tailight mod here somewhere.
