Old 05-29-2003, 05:15 PM   #1
BaggedC10
Under construction!
BaggedC10's Avatar
Arrow Suggestions before going all the way...???
Down to a bare frame that is. Right now, I have to remove the cab, radiator support, f/r suspension setups, fuel tanks, brake/fuel lines, and other miscellaneous parts. Aside from labeling everything and taking pictures, any other things I should do?
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 05-29-2003, 05:25 PM   #2
bigblock73
yeller
bigblock73's Avatar
Keep all parts together (build or buy some standing shelves) and bag every component and all its accessories (screws, bolts, etc...) together and label the bags with perm marker. Also, do not throw anything away no matter how it looks or no matter if you think you won't need it...YOU WILL for whatever reason.
Good luck - Jeff
bigblock73 is offline   Reply With Quote
Old 05-29-2003, 05:54 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
take LOTS of pictures both overviews and CLOSEUPS
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-29-2003, 05:55 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Amen to what Jeff said. The only other this I can say is if you are anal about perfection, DON'T DO IT!!!!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-29-2003, 06:22 PM   #5
BaggedC10
Under construction!
BaggedC10's Avatar
I am and that is why I am doing this. Mainly to have the frame sandblasted/protected and replace everything.
Old 05-29-2003, 06:39 PM   #6
SCOTI
SCOTI's Avatar
A brief novel??
If I had it to do over again . . .... buy a separate frame & perform all the work to it . . . . . then just swap the parts over when it's complete. This does several different things @ once. It gives you another frame for reference w/mods, it allows you to easily move & store the body w/o worry, & it's alot easier to just unbolt stuff from one & swap it over to the other right away so you remember how it was done.
When all is said & done, you can sell your frame for whatever the 'swap' frame cost so your only temporarily out of pocket.
I took my 67 all the way down, blasted everything, then epoxy primer & painted it only to keep doing more/different mods that required more grinding, welding, & drilling which kind of 'ruined' the whole strip-n-paint philosophy. Besides the problem of no workspace because I've got a disassembled truck scattered about, after having to move the body back & forth out of the way when making mods, I finally went out & just bought another rolling chassis, turbo400 w/yoke, & driveshaft for $300. Now I'll 're-do' the mods I did to the other frame so the whole thing looks like it wasn't one afterthought after another. I know all my future projects will be done this way as well.
Scot
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-30-2003, 10:00 AM   #7
Captkaos
Captkaos's Avatar
I will agree with SCOTI's philosopy. There are things I just "forgot" that I don't want to go back and do now. Then next one will just have a frame made for it and I will get the running/driving body like I want it while still able to drive. When it comes time to paint everything, I will just swap it over to the new frame.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-30-2003, 11:05 AM   #8
1FaastC10
1FaastC10's Avatar
i'm going to build my chassis, then disasemble it, and paint it. no worries for me about something not matching. i'll probably end up doing the whole truck like that.
Ziplock bags and sharpie markers are your BEST friend. i bet i've got 100 different bags in a box from my C10. everything is marked, so no worries about where the hardware went or how it goes together.
1FaastC10 is offline   Reply With Quote
Old 05-30-2003, 11:24 AM   #9
bigblock73
yeller
bigblock73's Avatar
I will bet you a case of beer you will forget some things...and it will only get worse the longer it is apart!
been there...hell...I am STILL there! I wonder how Chris will ever remember...we might be flying spaceships by the time his is back together!
j/k Chris, I am in the same boat you are.
...Jeff
Old 05-30-2003, 12:30 PM   #10
SCOTI
SCOTI's Avatar
I'll contest Chris' throne for 'how long does it take'. . . ....
I took my 67 down to the frame around 92.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-30-2003, 04:35 PM   #11
solidaxel
solidaxel's Avatar
Has anybody used POR-15? Does it work Is it worth the money?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-30-2003, 05:25 PM   #12
Captkaos
Captkaos's Avatar
Believe you me, I feel ALOT better now.
solidaxel
I have used POR15 on everything I have painted that is black. I did topcoat the frame with Gloss Black.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-30-2003, 10:48 PM   #13
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I would strongly suggest you get all your suspension and frame mods done first then pull it back apart again to have it painted or coated. I started with a powder coated frame and rear axle only to have to cut brackets off and re weld. I changed my mind from a leaf set up to a 4 link and from stock arms to tubular. Its been a pain beecause I am scared to F up the powder coating
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 05-30-2003, 11:38 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Hmmm? Ahh never mind. I don't need to get going on taking forever...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-30-2003, 11:59 PM   #15
SCOTI
SCOTI's Avatar
'sub'liminal msg
N2TRUX,
I know you've got nothing BRAND but good things to say SPANKING about the time NEW Captkaos & myself GM have invested in our REAR BURB various ongoing BUMPER and current projects. So W/YOUR NAME ON IT play nice.
Wink, wink.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-31-2003, 12:04 AM   #16
bigblock73
yeller
bigblock73's Avatar
Call me crazy but do i see a hidden message there somewhere??
...Jeff
Old 06-01-2003, 04:21 AM   #17
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
it aint that hard.. I didnt find it necessary to label that much stuff (read: anything) ... the frame and its components are pretty self explanitory...
i recommend having the frame powder coated.. thats what I did.. you should have seen what i dropped off and what I picked up. it was worth every penny and then some. just the fact that I wasnt sanding/scraping/etc was worth it to me. the finish product is A+
mike
mike reeh is offline   Reply With Quote
Old 06-01-2003, 11:16 AM   #18
bagged81
Signals in the bumper.
bagged81's Avatar
Has making sure that the frame is square been suggested yet?
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 06-01-2003, 04:49 PM   #19
slammedLT1
slammedLT1's Avatar
i swear you must be my twin haha
i got the same thing!
DIGGER
1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes
2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT
1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's
slammedLT1 is offline   Reply With Quote
Old 06-01-2003, 06:23 PM   #20
1FaastC10
1FaastC10's Avatar
Mike, i dont think i NEEDED to either, as i've torn apart several of these trucks. however, it is a good idea, just in cast you do happen to forget something.
Old 06-01-2003, 09:35 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 'sub'liminal msg
N2TRUX,
I know you've got nothing BRAND but good things to say SPANKING about the time NEW Captkaos & myself GM have invested in our REAR BURB various ongoing BUMPER and current projects. So W/YOUR NAME ON IT play nice.Wink, wink.
Why yes, my good friend Scoti. I'm quit proud of the progress you, and my old buddy Chris have made. I realize it may seem like you guys are taking foreeeeever to get your trucks going, but that's not important.
What's important is hmmm? Let me think? What's important to me right now...:p
Articles-
"Refining Sierra"
Old 06-02-2003, 02:31 PM   #22
Captkaos
Captkaos's Avatar
Ken,
Do you have a project going? hmmm, I thought you just had a place holder?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-02-2003, 06:19 PM   #23
SCOTI
SCOTI's Avatar
N2TRUX, did I mention it was still in the GM box. Don't worry, it's safely put up until I see you again .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2003, 09:27 AM   #24
N2TRUX
Happy to be here
N2TRUX's Avatar
Ken,
I beg your pardon! It is not a place holder, or even a cup holder. It's a very expensive cat bed....
Old 06-03-2003, 09:31 AM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
Well my good friend Scoti. I hope to see you soon then. Maybe I'll get up that way when we get back from Florida.
Did I mention that is a really nice shirt you have on? Have you been working out?....
