Old 10-07-2012, 08:10 PM   #1
bk04z66
floor replacement questions
So I am cutting out the old floor in my 71 k5, I bought the whole replacement truck floor. I noticed where the console goes the factory floor is flat, and the truck replacement has 2 beads in it, I dont have a console yet so I cant check but do I need to cutout the beads for the console to sit flat?
Also there are 2 holes under the gas pedal, I imagine these are for the organ type pedal?
bk04z66 is offline   Reply With Quote
Old 10-08-2012, 09:25 AM   #2
jaros44sr
jaros44sr's Avatar
Re: floor replacement questions
Those reinforcement ribs shouldnt be in your way, since the console sits on top of the 2" raised area right behind the trans cover. Console has 4 raised feet, about 1/2" tall
Never did figure out why they put those ribs there, i guess, just reinforcement
Post up pics of your progress....
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-08-2012, 03:26 PM   #3
bk04z66
cool thanks, if they needed to be taken out I wanted to do it while the panel was loose. I have a build thread going, Ill add some pictures of the destruction this weekend.
Old 10-09-2012, 09:53 AM   #4
jaros44sr
jaros44sr's Avatar
They are only 3/8" raised, arent they? Just so im thinking of the same part as you. Try to include some demensions in your pic and i will make sure they dont hit the console
SAFETY FIRST
AS usual, off topic
Jim
Old 10-09-2012, 02:56 PM   #5
72blazerblue
72blazerblue's Avatar
The ribs won't hit the center console. I put a new truck floor in my 72.
http://67-72chevytrucks.com/vboard/s...=513215&page=2
1967 SWB C-10
1972 Blazer 4x4
2011 Silverado
72blazerblue is offline   Reply With Quote
Old 10-09-2012, 03:54 PM   #6
bk04z66
Thanks for the link, did you weld up all the extra truck holes in the floor? I am thinking about leaving the the truck seat mounting bolts in, just in case I ever want to throw a bench in it.
Old 10-09-2012, 08:08 PM   #7
72blazerblue
I left mine in as well. I figured it'd be good to keep em cause you never know when you might want to change things!
1967 SWB C-10
1972 Blazer 4x4
2011 Silverado
Old 10-17-2012, 01:40 PM   #8
David623
I am getting ready to order a bunch of parts for the "tub" how difficult is it to replace and is there any modifications to the replacement floor?
David623 is offline   Reply With Quote
Old 10-18-2012, 09:25 AM   #9
bk04z66
i am not done yet, I will post some more pics in my build thread tonight. There are mods to the truck pan that need to be done. Big ones I can see right now are cutting off the rear off the rear support, adding all the blazer seat supports, plugging up all the truck holes(fuel line, seatbelt holes, acc pedal holes, fuel tank,etc).
