Old 10-08-2012, 10:52 PM   #1
Sodak
Active Member
Gas Tank and other Questions
Got a 78 chevy duel tanks and this truck has lived a hard life ,not sure if these are the original tanks/sending units or not.Basically it has three lines coming out,1 is the main line @ is a vent(to where i have no idea) and 3rd is the return.
Now my question is ...How do i go about hooking these up ,And to what, in the manual it says i needed a three port one wire tank diverter(Got it) also there is no extra port on the mechanical fuel pump and again don't know where the vent goes. would it just be easer for me two replace the sending units with a two port?
Next question.
Where do i find gas tank filler hoses? Can't seem to get themat a chain store or online that i can find.If someone can steer me in the right direction i'd appreciat it.
And finally(for now) i have a 73-74 grill and the bowtie is missing (sticker part) where can i get a new one .She just doesn't look right without it.
Thak you guys for any and all help.
Shane
Sodak is offline   Reply With Quote
Old 10-08-2012, 11:06 PM   #2
frog210
Re: Gas Tank and other Questions
i think there should be a canister where the vent goes
about the filler hose i think a member here said that they had used like a radiator hose dont quote me tho
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 10-08-2012, 11:21 PM   #3
GM-power
GM-power's Avatar
The vent line goes to the charcoal canister in the engine bay. There are two ports on the pump. The larger one is the supply smaller is return. The vent goes from tank to canister non on the pump. And as for a filler hose I think a radiator hose would work.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 10-08-2012, 11:22 PM   #4
Sodak
Active Member
Thanks for the reply,sorry but I have no cannister neer the fuel tanks,and won't gas eat a radiator hose? guess i'll have to call napa in the mornin and see.
Just noticed the reply above and i have no cannister in the engine compartment or a second port on the pump,can i just leave them pluged like i found them or should i get a 2 line sending unit?
Old 10-08-2012, 11:25 PM   #5
GM-power
GM-power's Avatar
The canister is located in the RH front side of the engine bay right by the radiator. You don't need one but when your around the truck it will smell like gas.
Old 10-08-2012, 11:29 PM   #6
Sodak
Active Member
What about just leaving it pluged like i found it?
Old 10-08-2012, 11:32 PM   #7
GM-power
GM-power's Avatar
That's a bad idea. If you have the fuel vapors building up it'll pressurize the tank and could explode. Oh and classic industries does have a filler neck, and im sure they have a charcoal canister as well.
Old 10-08-2012, 11:33 PM   #8
frog210
i didnt have that canister on my 74
its only two pronged on the sender
San Antonio, TEXAS
-Frog
Old 10-08-2012, 11:41 PM   #9
Sodak
Active Member
See thats what i'm wondering can i replace my 3 port sending unit with a 2 port? and where does the second port go by the way?
Sorry i guess i'm not explaining things too good here,The metal part is fine it's the gashose i can't find,As in discontinued so says napa.but if like you say radiator hose should work then i'll try to match something up there.i just thought gas would eat it for some odd reason.
Old 10-08-2012, 11:45 PM   #10
GM-power
GM-power's Avatar
Classic industries part#G2666
Old 10-09-2012, 12:01 AM   #11
Sodak
Active Member
Still in the catalog but discontinued i am going to try the 70-81 version part #g2670
Old 10-09-2012, 04:20 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
my Jimmy 78 didn't come with the cannister
79 did tho
78 stock 305 2 gas lines
79 stock 305 3 gas lines
for me it was 3/8 feed
5/16 vapour
1/4 liquid return
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-09-2012, 04:24 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
not the tank vent eh?
John
Old 10-09-2012, 06:43 PM   #14
Sodak
Active Member
79 did tho
5/16 vapour
1/4 liquid return
In the first pic i see the cap on the end of the vent line where do i get thoseand second i think i will order two -two line sending units .I don't have the lines any way or the cannister,so no sence confusing me or some one in the futer with what should or should not be there.and that last pic i don't even want to know where all those lines go.lol
Thanks guys for all the help on this issue i appreciate it.
Old 10-09-2012, 06:51 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
Those are used as diff vents too
John
