But Found Her 25yrs Later!
![]() Join Date: Oct 2010
What's your Winter Goal?
The time I've been around these and other classic truck forums,
I've noticed that many try to do their major work during the rainy season. There's a thread like this in other classic vehicles forums. I thought we needed a thread about goals for this winter. Mine is to get my rear swapped out to the 3.07 12-bolt And while I'm there, swap out the rear springs for bags. Some other miscellaneous things, but those are the two major things I hope to get done this winter.
![]() Join Date: Mar 2011
Re: What's your Winter Goal?
My goal for the summer was to get the patch panels done on the cab floor and rockers and then tip the cab on it's back and strip and coat the bottom and sand the inside of the roof while it's convenient. That didn't get done except for the passenger side, so I will continue to patch the drivers side floor and rockers and get primer on what I can before it gets too cold, unless I can locate a suitable heater for my garage. The next priorities are:
1)finish installing the front calipers, rear drums and brakes, emergency brake cables, and run the brake lines. 2)finish up my rear fuel tank install and run the fuel line to the front. At the rate I'm going, that should keep me busy through the winter AND next summer. |
I'd like to have a rolling chassis with engine by the end of winter, and to dabble on the body work a bit.
Yeah, things seem to take longer than anticipated.
Next summer (while it's dry and warm) I hope to get started on the body.
My goal is to keep driving my 64 everyday. Lets hope goes back down at least a buck Or i may be forced to get anothet car for my dd. I really dont wanna do that
Posted via Mobile Device |
I'm still down with hip problems but my realistic goal for winter (I hate cold!!) is to get the carb optimized for the cold weather and put the fenders on with the help of my daughters. The younger one is just getting old enough to enjoy getting her hands dirty. She'll be my main little mechanic
Step by steps: Remove primer to reveal original paint Rebuild a carburetor See My Build - Cecilia! ![]() Some people are like slinkys. Not worth much but funny as heck when pushed down stairs. |
I haven't touched my truck in months. Too many to count in fact. My goal this winter is to get my truck moved to a new location and work on it on my off time. Now that I am back to work, it's time to get back to work.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Putting the LS drivetrain in and getting it buttoned up by the spring to be my daily driver.
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803 Dennis H 1969 Chevy C10, SWB, LS3,6.2L engine 1969 Chevy Chevelle SS,BBC, Convertible |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
I know what you mean. My work has been slow to non-existent. If my work pics up like my business partner says it will, I will get back to getting my frame stripped and powder coated and have the chassis rolling and ready for the body come spring time
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Front end rebuild, disk brake kit, new brake lines on the top of the list. Would like to get my new front end dropped on if time permits.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Im giving up hope on my 72 truck ever coming home so my winter project will be to add a stereo system to my wifes 72 Malibu convertible ,find the leak in the top mechanism ,and get the speedometer to register correctly . I may do a few small things to my daily driver 74 stepside but mostly just drive it .
to get my heater working again... so i dont freeze to death
the Stealth Weapons 63 project, all comments, advice, and critiques welcome! http://67-72chevytrucks.com/vboard/s...d.php?t=438235 |
SIR
...survive till spring....
66long low fleet http://community.webshots.com/user/LVNR66 |
Keepin it old school
New tires and hubcaps then lower stance. Maybe replace fenders and rockers if the money situation is right.
#15 |
GMC's n H.D.'s too!
Shooting for road legal!
She is running decent, and stopping now, just need to get the radiator changed out, redo the wiring, swap out the fluid in the transmission and transfer case, and grease the wheel bearings. She wont be real pretty to many people, but she'll be rolling down the road for those of us who appreciate true beauty! |
#16 |
![]() Join Date: Aug 2004
I think ill try to find a really good hood ( to save on body work) and maybe switch the rear springs to airbags so I can tow something if I am so inclined. Also finish a couple bad body spots that are nagging at me. and drive it in between!
Jason, we think she is damn pretty!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#17 |
GMC's n H.D.'s too!
#18 |
1. Get the cab painted
2. sand blast and paint inner fenders 3. Assemble front end and start body work 4. Run wiring and install heat and air
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
#19 |
Hoping to either start building my engine (found a 4 bolt main 350 on CL for $100!) or start tearing down the front end and rebuilding it. Disc brakes, suspension, etc. I'm in for a busy winter I think...
#20 |
Winter goal.....? Get the Dang thig finished!!! Sooooo close.
#21 |
Drive it as much as I can. Without ac 100 degrees is just to hot to drive it during the summer.
#22 |
Winter goal. Get my 1966 International 404 tractor running!
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
#23 |
bag it and new metal for the floorboards and various body sections
#24 |
1. Buy a used 5.3 locally.
2. Get the engine/trans mounts fabbed. 3. Finish the frame bracing. 4. Get the bed undercoated, buffed out, polish the side trim, and install wood floor so its ready to go back on the frame. 5. Keep an eye out for a buildable LS2 block.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#25 |
-get the engine and trans built and installed in the '68 chassis
-finish cab metal patches, and seal/paint floor and firewall on the '68 cab -mount cab back on chassis to get it ready to begin paint and bodywork
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
