Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-09-2012, 07:43 AM   #1
D-Wake
skinnies
I have a 79 c10 and I'm trying to find some skinnies for up front and 15x10s or 12s to run out back. Being the fact I'm cheap I'm trying to find some used ones but I keep finding mustang 15x10s with 6.5 backspacing I'm not really sure if I understand this right but if I use wheel adapters that space it out 1.5inches will that make then be the correct back spacing for our trucks?
D-Wake is offline   Reply With Quote
Old 10-09-2012, 08:44 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: skinnies
5"
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-09-2012, 08:49 AM   #3
D-Wake
Re: skinnies
So a 1.5 spacer on a rim with 6.5 backspacing makes the rim 5 inch spacing? That's what I want correct? Btw truck is lowered with flip kit in rear spindles and coils up front. I'm just trying to make sure it'll all fit before I spend the money. Thanks
Old 10-09-2012, 08:54 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: skinnies
I am not there to look at the truck . But 6.5" backspace with a 1.5" spacer would be 5 " backspace . 1.5" is to much spacer .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-09-2012, 10:08 AM   #5
D-Wake
Re: skinnies
So I need 5.5 backspacing?
Old 10-09-2012, 02:05 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Re: skinnies
Yeah with so many wheels available, I'd SURE not run a spacer or adapter of any kind. If your wanting a 12" wheel out back, you better just figure on a narrowed rear or the tire is going to hit the frame, wheeltub, suspension or body. 12" is a LOT of wheel. I've got a spare set of ConvoPro for the pfhat look was on the 66 before it moved from show to more go oriented ( 15x15 with 5on5 w/ Hoosier 33x22.50-15's for the rear, and a set of 15x8.25's again in 5on5 patern,, yeah it redefined the term pfhat tire look, lol) So trust me when I say the rolling resistance of a buttload of rubber under a vehicle is not to be ignored. It's a SIGNIFICANT performance inhibitor .
For the front,, change the spindles / hubs or have some re-drilled for the patern you want. I'd not run an adapter on ANYTHING other than a boulevard cruiser. It's just not that safe no matter if your carving corners or going fast in a straight line.
but.... just my 2¢
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-09-2012, 02:18 PM   #7
D-Wake
Re: skinnies
Yeah I just read something about it not passing tech if I ever take it to the strip s.o I guess I'll scrap that idea. Thanks for all the help
Old 10-09-2012, 03:29 PM   #8
Marv D
Marv D's Avatar
Re: skinnies
D,, all that tech stuff is a PITA, and stupid expensive sometimes. but.... those rules were all made because someone got hurt / killed as a result of not building within those guidelines. Even if you were not headed to the track,, it's good food for thought in any build.
Old 10-09-2012, 09:02 PM   #9
djracer
djracer's Avatar
Re: skinnies
Centerline make some pretty nice stuff in 5 on 5. Here is the 15x12 I put on the rear of my son's truck.
and the front's
A Picture before I lowered it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-09-2012, 09:10 PM   #10
D-Wake
Re: skinnies
Wow that truck is really nice! That is the look I want. If you don't mind how much did that rim and tire combo cost?
Old 10-10-2012, 08:05 PM   #11
djracer
djracer's Avatar
Re: skinnies
I want to say I paid 900 or so for the wheels and I stole the tires. I paid 100 for the rears and nothing for the front.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
