Old 10-09-2012, 07:52 PM   #1
PurdueSD
PurdueSD's Avatar
Scotts Hotrods IFS in my 51
There is not a whole lot of information on these coilover ifs for AD chevys out there floating about the internet. Trust me i know! So i figured i would do my part and document my progress and maybe get some help and reassurance along the way. This is my first build to this extent and thus my first ifs install.
Anyways, made my decision and less than a month later had the kit sitting in my garage after working with Justin and getting a pretty good deal.
Fast forward to today. Got my parts unboxed and started some preliminary mock up. My intensions before all these ifs shenanigans started, was to send my axle out to be dropped and thus i had removed my axle without marking the centerline on the frame. A little digging and i found the centerline of the stock axle to be 20.594" from the end of the frame rails or 18.281" from the center of the shack le hole in the frame (care of the factory assembly manual). Here is a shot mocked in place...
PurdueSD is offline   Reply With Quote
Old 10-09-2012, 08:12 PM   #2
PurdueSD
PurdueSD's Avatar
Re: Scotts Hotrods IFS in my 51
Well it didnt take long for me to stumble into my first head scratcher. Mocked into place and centered where the stock axle used to sit... Something doesnt seem right.
In front and behind the crossmember wher it welds to the outside of the frame i have about a consistent 5/32nds gap.
On top of the frame raile i have between 3/8ths to almost 1/2" at the worst spot.
All this coupled with the fact the frame rails pinch towards the front....leads me to believe the cross member was ment to be install further rearward.
Old 10-09-2012, 08:14 PM   #3
Wvgearhead
We put a Scott's coil over ifs on my buddies 46 Chevy. A really nice piece, I almost pulled the trigger on their air ride ifs. Ended up with a tci. If I was to do it over, mine would have rolled on Scott's. After seeing one in person, I was sold.
Wvgearhead is offline   Reply With Quote
Old 10-09-2012, 08:44 PM   #4
55dude
55dude's Avatar
call Scotts and ask!
55dude is offline   Reply With Quote
Old 10-09-2012, 09:09 PM   #5
Scottshotrods
Call us at the shop at (805)485-0382
Justin
Scottshotrods is offline   Reply With Quote
Old 10-09-2012, 09:10 PM   #6
PurdueSD
PurdueSD's Avatar
Thanks for the call Justin!
Old 10-10-2012, 09:49 AM   #7
Russell Ashley
Russell Ashley's Avatar
Anyone know if you could put a suspension like that into a 57 if you removed the front clip but left the engine in place?
Russell Ashley is offline   Reply With Quote
Old 10-10-2012, 10:38 AM   #8
Scottshotrods
Yes you can, but on our weld in unit you will have to box in the frame where the front suspension goes.
One more option for you we do have a bolt in unit for your truck!!
If you have more questions call us at the shop at (805)485-0382
Justin
Old 10-10-2012, 01:36 PM   #9
meter swinger
meter swinger's Avatar
Justin
Any pics of this unit anywhere Justin?
meter swinger is offline   Reply With Quote
Old 10-10-2012, 01:46 PM   #10
Scottshotrods
We will be putting up a new link on this today showing the frontend and listing all the other bolt in frontends we have now for TRUCKS.
Justin
Old 10-11-2012, 03:29 PM   #11
dcmalone
dcmalone's Avatar
Justin
Is the link up yet?
dcmalone is offline   Reply With Quote
Old 10-10-2012, 05:23 PM   #12
jephs422
Here's a few images of our 48-54 Bolt in. Sorry for the lack of detailed shots. Camera is having some technical difficulties. I'm working on it.
Remember, we have a weld in or bolt in for this truck.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 10-10-2012, 05:44 PM   #13
Scottshotrods
We also have the 55-59 chevy truck bolt in ifs.This can be ordered with bags or coil-overs.
Justin
Old 10-10-2012, 06:03 PM   #14
meter swinger
D@MN...
Old 10-10-2012, 07:35 PM   #15
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
hey purdue.my scotts croosmember was the same way.we just added some plate steel to fill the gap on the crossmember and burned it in.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 10-10-2012, 08:14 PM   #16
PurdueSD
PurdueSD's Avatar
Yep thats what Justin and I spoke about last night. So today I (crudely) took some 1/8th inch plate i had laying around the shop and mocked it up into place on both side. Should work out really well.
Chizz- did you offset the the plate so there was two weld joints? Or did you cut it 4" wide so it was slush with the crossmember?
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
Old 10-10-2012, 08:27 PM   #17
CHIZZLER
CHIZZLER's Avatar
flush with crossmember.then ground down a little.good luck.
61-crew cab D-max
Old 10-10-2012, 08:31 PM   #18
CHIZZLER
CHIZZLER's Avatar
what are your plans with the rest of the truck?any pics of truck?
61-crew cab D-max
Old 10-10-2012, 10:42 PM   #19
PurdueSD
PurdueSD's Avatar
6.70 firestone ww on black oe style wheels
donor suburban tbi 350/700r4/gas tank
Explorer rear axle
Suburban booster/ master/ pedal assy
Freshen up interior
New chrone and cream grille
Couple misc body panels painted to match for now
Some pinstriping
Plan to patch a couple bad spots here and there and blend them back to match.
(outside stays old and worn for a couple years)
Ive spent alotta time over the years tearing stuff to the ground and never gotten to enjoy driving one. That is the main goal on this one... or so i keep telling myself as i tore this chassis to the ground. Body can come back off later. It will be super safe and really fresh and clean underneath.
My build thread is in my sig below, it kinda shows some of my progression.
Old 10-10-2012, 11:50 PM   #20
CHIZZLER
CHIZZLER's Avatar
found your build.nice work.i have about 1000 miles on my burb and the scotts ifs and 4-bar are quality stuff.chizzler
61-crew cab D-max
Old 10-11-2012, 11:34 AM   #21
98layinframe
98layinframe's Avatar
What's the track width on that Scott's setup?
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 10-11-2012, 11:53 AM   #22
Scottshotrods
60 1/2 inches wheel mount to wheel mount.
We can build them at different track width if need be.
Justin
Old 10-11-2012, 06:22 PM   #23
98layinframe
Justin
Thanks. At that standard width, do you know if my 0 offset (4.5" backspace) wheels will tuck up inside the wheel wells with plenty of clearance to lay it out on air ride?
Old 10-11-2012, 06:25 PM   #24
Scottshotrods
You will be fine
Justin
Old 10-13-2012, 03:30 PM   #25
PurdueSD
PurdueSD's Avatar
Got the frame boxed and the rails prepped!
