10-10-2012, 10:58 AM | #1 |
Front end suspension rebuild kit
On my 64, everything on the front end is original and parked for 15+ years.
I was looking at replacing all this via a kit I found online. Have you guys found all this to be necessary or worth the time? OUTER LEFT-HAND TIE ROD OUTER RIGHT-HAND TIE ROD LEFT-HAND TIE ROD SLEEVE RIGHT-HAND TIE ROD SLEEVE SWAY BAR FRAME BUSHING INSULATORS (2 EACH) LEFT-HAND UPPER BALL JOINT RIGHT-HAND UPPER BALL JOINT LEFT-HAND LOWER BALL JOINT RIGHT-HAND LOWER BALL JOINT LEFT-HAND UPPER CONTROL ARM SHAFT KIT RIGHT-HAND UPPER CONTROL ARM SHAFT KIT LEFT-HAND LOWER CONTROL ARM SHAFT KIT RIGHT-HAND LOWER CONTROL ARM SHAFT KIT Thanks for the tips
1964 Chevrolet C-10 SWB Fort Worth, TX |
10-10-2012, 11:41 AM | #2 |
Re: Front end suspension rebuild kit
Never hurts to upgrade the suspension or brakes to some newer parts as long as the parts are quality pieces and not cheap chinese parts. Suspension parts have come a long way in the 50 years since these trucks were made. Although not always necessary, you should notice a difference in the ride and handeling of the truck by replaceing the parts above. If replaceing all these parts, Id heavily consider new springs and shocks too, or at least new shocks.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
10-10-2012, 11:47 AM | #3 |
Early Classic has a total front end rebuild kit with Moog parts. It's around $600, but you get all you need to totaly upgrade the front end.
http://www.earlyclassic.com/catalog.aspx |
