Old 10-10-2012, 06:55 PM   #1
BuckTruck16
Master Cylinder line issues
We have a '79 k10 with a 5.7L, with a disc/drum setup. We just replaced all the lines but are not sure what lines go to what. As in, the master cylinder has 2 ports. The one in the front is larger than the one in the back. Is the bigger port in the front for the front breaks or rear? And which one goes in which for the proportioning valve?
-Thanks
BuckTruck16 is offline   Reply With Quote
Old 10-11-2012, 08:51 PM   #2
BuckTruck16
Re: Master Cylinder line issues
Any luck?
Old 10-11-2012, 09:09 PM   #3
Keith Seymore
Keith Seymore's Avatar
The larger part of the reservoir, regardless of whether it is at the front or the rear of the master cylinder, goes to the front discs. This is because the disc brake pistons take more fluid to actuate than the rear wheel cylinders.
I believe that same brake line goes into the proportioning valve because it has a "hold off" feature which keeps the discs from applying until the slack has been taken up in the rear shoes.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-14-2012, 08:47 PM   #4
BuckTruck16
Thanks Keith, your always there to help me. Appreciate greatly!
Old 10-17-2012, 07:56 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
on my 78/79 the larger line is the rear,smaller res hole
from the valve it goes two small to the fronts
1 large to the rear
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
