1 more ? for the day - throttle linkage for edlebrock carb with 283 and manual trans
do i need some sort of adapter or do i need to remove the metal rod linkage and replace with a cable actuated setup?
thanks again! - jason |
Re: 1 more ? for the day - throttle linkage for edlebrock carb with 283 and manual tr
sorry its a 63 c10 with factory 283 and factory 4 speed floor shift
Not sure if this helps but when I changed out my intake I upgraded my throttle linkage. I used to heim joints and a pieve of 5/16 fine threaded rod (I think). I used shoulder bolts to fasten heim joints to the carb, and throttle linkage. If this helps, I could take it apart and take more detailed pics.
Let me know!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
I should note that my carb is a holley, and my truck is a 66, but the engine is a 283
No issue, it is currently serving as the PCV valve port. It is actually on the deck of the block between the distributor and the firewall. It's days are numbered though as I am about to order a 350 crate engine, just way too expensive to even think about rebuilding the 283.
thats awesome - thanks for the ideas!
as for the vent thing i simply pulled igt and installed a freeze plug and used valve covers with an oil filler, a breather and a pcv valve to the carb. hope that helps! |
I have a 66 that had a 2bbl/283. Dropped in a 350 with a AFB 4bbl. old style manual 4sp tranny. Used original rod and ends for the throttle linkage... Just beefed up the return spring. Works great.... so far.
mr gasket makes a aluminum bushing that fits the opening on the edelbrock throttle linkage
to correct the factory rod Posted via Mobile Device
///Relaxed Atmosphere |
