Old 10-11-2012, 08:58 PM   #1
71chevystep4x4
71chevystep4x4's Avatar
proper exhaust for a 5.3
I'm just curious to what all you other 5.3 swappers are running size wise for exhaust? My headers are Hooker block huggers that were a LS1 application with 2" reducers, and I originally figured I'd run 2 1/2 dual pipes with a H pipe, but would like a final opinion on if just 2" would be adequate.
71chevystep4x4 is offline   Reply With Quote
Old 10-11-2012, 10:08 PM   #2
Kim57
Kim57's Avatar
Re: proper exhaust for a 5.3
I'm no expert but everything I've seen says the LS engines like large pipes.
I'm planning on running 3" exhaust on my LS-2.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-11-2012, 10:31 PM   #3
crazy longhorn
Fabricate till you "puke"
I think I would go 2 1/2" on the system on the 5.3. The headers no doubt, have a 2 1/2 " outlet.....ditch the reducers, & opt for a set of weld rings? Then you just carry the 2 1/2, right off the collectors....(the way I plan to do my swap....dollars still pending) crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-11-2012, 11:04 PM   #4
clinebarger
2 1/4" would be fine on a 5.3, Are you sure the reducers are 2"?
clinebarger is offline   Reply With Quote
Old 10-12-2012, 12:45 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
Factory 2010+ Camaro 6.2L LS3 exhaust manifolds have a 2.5" outlet.... I have a set for my 6.0L LQ9 going into my K5 Blazer. I had a set of exhaust flanges cut out of 3/8" steel on a cnc waterjet. The Blazer came to me with 2.25" exhaust with flow masters. Since the mufflers are still good, I will just reduce it at the muffler. I will eventually change them out but not spending the money now....
Rich
1972 K5 Blazer CST Click HERE
Old 10-12-2012, 10:23 AM   #6
Clyde65
Clyde65's Avatar
I thought most trucks had single exhaust that was 3inches. I would think stock 6.0 would be fine with dual 2-1/2" easy and give it max breath-ability.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-12-2012, 10:40 AM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
My 5.3 had a 5" exhaust on it for awhile....(coming off the turbo )
When it was N/A I had stainless JBA shorties, dual 2.5" thru magnaflows.
Here's a sound clip
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-12-2012, 06:12 PM   #8
OKGMC4
OKGMC4's Avatar
I sized mine using this chart...
http://www.dynomax.com/assets/2008ca...enginesize.pdf
According to that, dual 2.5 exhaust is good to at least 350 hp with turbo mufflers. Most 5.3 engines are somewhere around 300hp.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 10-12-2012, 09:12 PM   #9
71chevystep4x4
Yeah I was really surprised that they are only 2", they taper right below the flange, I'll probably just cut them there and weld on some 2 1/2 pipe and reweld some O2 senser bungs I guess.
Old 10-12-2012, 09:41 PM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I just found that the Hooker exhaust manifolds are also 2.25". Seems small.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-12-2012, 09:45 PM   #11
mcmlxix
mcmlxix's Avatar
HOLY BIG PICTURE Kurt .... lol
714x4... Is it just the reducer thats small or is the actaul manifold outlet small? Can you just replace the collector?
Rich
Old 10-12-2012, 10:08 PM   #12
71chevystep4x4
Its just the reducer, I'll probably just cut it at the taper and weld 2 1/2 on it. The headers are intended for ANY tight fit LS swap application, maybe they just sized them down for that. I just asked because I really didnt want to run 2" pipes.
Old 10-13-2012, 10:30 AM   #13
68GMCCustom
You must have post when I was still in the "editing" phase. Didn't have a clue it was going to distort the page like it did....then couldn't find a "reasonable" size pic...just the thumbnail.
odd name for a pic size.................thumbnail.
Kurt -
