Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 10-12-2012, 09:07 PM   #1
79 silverado
Carbs - 2bbls, 4bbl Q-Jets, 4bbl Holleys
Still have a shelf of spare/leftover carbs out in the workshop. Now priced individually below:
Carb #1 - Decodes to a 600 CFM Holley - Single fuel line feed $75
Carb #2 - Decodes to a 600 CFM Holley - This carb is aluminum lightweight body, has a split chromed double duel line feed as seen. $85
Carb #3 - Q-Jet decoded on an online website as being a 1977 with a 750cfm rating on the body, recommend you verify independently to your satisfaction before purchase. $35
Carb #4 - Q-Jet decoded on an online website as being a 1980 5.7L with CA Emissions package, recommend you verify independently to your satisfaction before purchase. $50
Carb #5 - Rochester 2-Jet "Bay City" carb, decoded on an online website as being a 1974 350 2bbl with AT carb, recommend you verify independently to your satisfaction before purchase. $40
Carb #6 - This is an old "2-jet" carb from back in the days when a small tab would be attached to the top indicating what it was from. This tab/tag is long since missing, and thus there is no easy way to truly determine what it was from. May have been an early 60s full-size car since I had a couple of those come through at one time that I still have radios and trim for so it is very possible it was from one of those. $40
I photographed the casting/part numbers for all of these so please verify that you know what you are getting beforehand - I tried to get an idea on their original applications from online resources, BUT, of course I cannot 100% guarantee the accuracy of those web resources so buyer is ultimately responsible.
79 silverado is offline   Reply With Quote
Old 10-12-2012, 09:45 PM   #2
qadeem
qadeem's Avatar
Re: Carbs - 2bbls, 4bbl Q-Jets, 4bbl Holleys
How much for carb #3 to 80247?
qadeem is offline   Reply With Quote
Old 10-12-2012, 10:30 PM   #3
79 silverado
PM Sent
Old 10-12-2012, 11:18 PM   #4
qadeem
qadeem's Avatar
PM sent.. Thank a lot
Old 01-14-2013, 05:44 PM   #5
79 silverado
Still have these... New year, new price, and I'll throw in a disassembled q-jet for parts as well!
Old 01-15-2013, 08:20 PM   #6
superwade57
Can you please send more info and shipped price.for #3 to 53548. Does it need a rebuild? Which choke is it?
Wade
superwade57 is offline   Reply With Quote
Old 01-15-2013, 08:58 PM   #7
79 silverado
Wade
On this one I would recommend a complete teardown and rebuild. While most of these carbs were on engines when I removed them and put them on the shelf over the years, carb #3 I remember coming loose in a box when I picked up a disassembled project vehicle years ago.
There is some oxidation on the gasket surface that should be cleaned up.
As regards the choke, it is a nonelectric type but the the choke itself should be replaced. (Opportunity to install the electric conversion one if wanted) The raised surface with the slot you put a screwdriver in and turn to adjust has had a piece broken off on it.
The online shipping estimator gave me a price of just over $18 to send, probably due to the weight. If you're interested how does $50 shipped sound?
Old 01-15-2013, 09:39 PM   #8
superwade57
Price sounds fair but I'll have to pass. I'm looking for a ready to go bolt on to improve daily drivability on my brothers 71 as the edelbrock is giving him gallons per mile instead of miles per gallon.thank you tho!
Old 01-25-2013, 12:02 AM   #9
79 silverado
Bump...
And adding one more carb to the line-up. $150 plus shipping, firm on this one (sorry, its on the lower end of what they go for based on what its from)
This is a 1978 W72 trans am carb with an 800cfm valve body from the factory per online w72 specs page. Originally for a bandit trans am type car with the hi-po pontiac 400ci pkg and auto trans. Date coded for a fall build. I stashed it due to the performance nature and the valve body being larger than usual, but I'm in a get-rid-of-stuff mood lately and would rather resist the idea of stuffing it on a bigger motor in my firebird... here the pics:
(Some of these the flash was going off, others it wasn't... don't ask me why???)
