Old 10-13-2012, 10:46 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Can someone ID this disc crossmember..
Was told its 71 72 anyone confirm this?
John
1999 Toyota Tacoma 4x4
Old 10-14-2012, 12:00 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Can someone ID this disc crossmember..
Judging by the steel bushed arms and disc spindles, if its all original, I'd say yes, it's 71-72
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-14-2012, 07:12 PM   #3
oldblue1968chevy
My rear axle from backing plate-backing plate is 56"
Do I have the wide rearend? truck is a 69 or 70 Im not sure how to tell.....
Going to look for axles if its the wider of the 2.
Will any 71-87 5 lug axle slide in if its indeed the wide rear?
John
Old 10-14-2012, 08:12 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
I think that's the wider version. Check wheel mounting surface--it should be 63.5". If so, later 5-lugs will swap right in...
-Chris
Old 10-14-2012, 09:49 PM   #5
thenormans05
Looks like a 71-72 to me also
thenormans05 is offline   Reply With Quote
Old 10-15-2012, 12:48 AM   #6
oldblue1968chevy
So take the wheels off and check drum-to-drum?
I'll do it in the AM would be nice if it was the wide version...
71-87 axle? or just 7172
John
Old 10-15-2012, 12:57 AM   #7
oldblue1968chevy
Who makes the best/cheapest drop spindle 2.5"
http://www.performanceonline.com/71-...e-2-half-inch/
http://www.earlyclassic.com/catalog.aspx
http://www.summitracing.com/search/Y...=drop+spindles
I liked ECE but for the extra $25.....
Also I can find a few other things for front suspension via summit bushings shocks and maybe replacement Bj's and suspension parts (if they carry moog or similar)
John
