Old 10-15-2012, 05:27 AM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
radiator info
im trying to figure out what rad i have so i can get the proper rad hoses, i cant seem to find the right info in my searches on here or good pictures
i dont have any pics of my radiator as its at my friends house but i can get some later today (mon) if needed, i dont think its the original to my truck since the truck used to have a straight six but the frnt clip was changed at one point from a 68 to a 69-72 gmc clip
what i do know is its either a 3-4 core rad, it fits in the rad supports and the rad hold downs fit it so i know its from these trucks, 3rd and final is the bottom outlet for the rad hose has an upwards angle to it and this is whats throwing me off, the rad hose that was on there didnt fit very well because of this, so im trying to find out if it came in a big block truck or maybe a 3/4 ton with a 350 and the years it came in so i can get a proper rad hose that fits
maybe we can start a sticky for the faq with the different types/styles of radiators and what year trucks they came in 4x4. 1/2 ton, 3/4 tone, 1 ton, bbc, sbc etc maybe even toss in some info on fan shrouds with the same idea too, im sure it would be a good and usefull sticky
i will get pics of my rad today
1972BackInBlackC10 is offline   Reply With Quote
Old 10-15-2012, 06:17 AM   #2
Square_78
Square_78's Avatar
Re: radiator info
This is very interesting and I hope some people can post some pictures. I have a 1970 gmc 1500 And my lower rad hose is rubbing on the frame rail. Pretty sure it's not supposed to do that. The radiator itself appears to fit correctly and it looks to be all the factory mounts. Are there any spacers that I may be missing from the bottom of the radiator? Even if I could raise it up a 1/4" it would be fine. Maybe it's just the wrong lower hose I have. It's rubbing about 3" or so away from the radiator itself on the top of the frame rail.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 10-15-2012, 07:28 PM   #3
1972BackInBlackC10
Re: radiator info
heres a couple pics of my rad, can anyone tell me what year or years it came in so i can get the proper rad hoses for it, i think its a 4 core
first is a pic of the angled outlet i was talking about, then a couple of the rad itself and one of a tag with numbers/letters on it
Old 10-15-2012, 08:27 PM   #4
hayhauler71
hayhauler71's Avatar
Re: radiator info
Radiator looks right to me
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-15-2012, 08:32 PM   #5
Square_78
Square_78's Avatar
Re: radiator info
Mine doesnt have that angled outlet on the bottom. Thats probably why my lower hose is resting on the edge of my frame rail...
#teamlongbed
Old 10-15-2012, 08:32 PM   #6
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: radiator info
The lower hoses rub on alot of these trucks, I have CU369 or A369 heavy duty radiator on mine.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-16-2012, 12:07 AM   #7
1972BackInBlackC10
Re: radiator info
can anyone give me a year or any info on what truck this rad would have came in? i need this info to give to the guy at the parts store so they can give me the right rad hoses
Old 10-16-2012, 01:32 AM   #8
1972BackInBlackC10
Re: radiator info
anyone? im not trying to be a pain but i need to buy these rad hoses tomorrow
Old 10-16-2012, 01:23 PM   #9
FirstOwner69
FirstOwner69's Avatar
Re: radiator info
Looks exactly like the original 4 row in my 69 except for that silver piece (added on?) at the top in picture 3. I've replaced the lower hose several times. The end that goes to the radiator typically needs to be shortened a couple inches to fit. Are you using an original style short water pump?
FirstOwner69 is offline   Reply With Quote
Old 10-16-2012, 01:37 PM   #10
1972BackInBlackC10
Re: radiator info
thanks im not sure whats on the motor for a water pump it isnt the original motor or rad this truck used to have a straight 6, and yes the previus owner added the top piece
Old 10-16-2012, 03:55 PM   #11
asolde
asolde's Avatar
Re: radiator info
Smitty
I just bought one of these radiators, how did it fit for you? Did the lower hose rub? Did you have to reroute your heater core hose back to the water pump instead of the radiator?
asolde is offline   Reply With Quote
Old 10-16-2012, 07:22 PM   #12
1972BackInBlackC10
Re: radiator info
i just got rad hoses for a 72, looks like they will work, im not a big fan of the flex hoses
Old 10-16-2012, 01:42 PM   #13
67chevemall
67chevemall's Avatar
Re: radiator info
Just get the hoses for a 1972 C10 with 350v-8..worst case you have to trim a bit off.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-16-2012, 02:47 PM   #14
Shyguy
Junior Member
Shyguy's Avatar
Re: radiator info
When I worked at auto parts stores if I had a customer that did not know exactly what radiator and engine they had I would suggest they take the diameter measurements of the radiator connection and the water pump and make a mockup of the bends with a coat hanger.
That way we could go look at the hoses we had and figure out what was needed.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 10-16-2012, 03:53 PM   #15
low&slow
Re: radiator info
Why not just buy a flex-a-fit hose?
low&slow is offline   Reply With Quote
