Old 10-15-2012, 12:04 PM   #1
Hazieview
Building Dreams out of Dimes!
Knocking off inner wheel weights off my 15" wheels with the drop I have any ideas?
Well I love the 15" rallies. I got 15x8s up front and 15x10s in the back.
I only have drop spindles up front and I keep knocking off inner wheels weights. Any suggestions? It looks to be hitting on the lower A arm but I really do not want to grind my A arm down.
Thanks!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 10-15-2012, 12:09 PM   #2
Jonboy
Slots go on anything!
Re: Knocking off inner wheel weights off my 15" wheels with the drop I have any ideas
Sounds like they are indeed hitting the A-arms. You don't have to grind much off of the lip, and it should go pretty quick.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 10-15-2012, 02:58 PM   #3
JCampbell
Wheel weights are overrated.
JCampbell is offline   Reply With Quote
Old 10-15-2012, 04:19 PM   #4
C-10 simplex
You may want to try those balancing bead things---that you actually put into the tire.
At first i was skeptical, but most people who use them say that they work great. And these are reliable sources.
C-10 simplex is offline   Reply With Quote
Old 10-15-2012, 05:29 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
My guess is you are running 3" drop spindles with those 15x8 wheels. Thats a common problem with that combo. You can grind the A-arm lip or go to a narrower wheel.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-15-2012, 08:21 PM   #6
71maligreen
have you tried useing the stick on type weights moved as close to the center of the wheel as possible???
71maligreen is offline   Reply With Quote
Old 10-15-2012, 09:40 PM   #7
BMERDOC
BMERDOC's Avatar
Gets my vote! Except keep to the outside of the inner lip. The further out the better.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-15-2012, 11:03 PM   #8
71maligreen
wouldnt that be where its closest to the a arm rubbing???
Old 10-16-2012, 12:34 PM   #9
BMERDOC
BMERDOC's Avatar
It would be stuck on the inner part of the rim and not so much the "lip". Note where it will clear and have them installed there.
Nick Carter
Old 10-15-2012, 08:56 PM   #10
76stepsidechevy
I'd go with the stick on weights, I tried the balance power stuff in a couple sets of tires and had horible luck with it. Never again, I'll run unbalanced tires before I use that stuff again.
76stepsidechevy is offline   Reply With Quote
Old 10-15-2012, 09:33 PM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
just trim the arms, its no big deal
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-15-2012, 11:21 PM   #12
kenbob87
kenbob87's Avatar
i run balancing beads in all my trucks ( the ones that go on the road anyway) and i love them your tires are always balanced and they are reusable when your tires are shot they can take them out of the old tire and put them in the new tire. the only negitive thing i have noticed with them is i get a slight vibration anything over about 110 but realistically how often do you get a chance or want to run up that fast?
kenbob87 is offline   Reply With Quote
Old 10-16-2012, 12:28 AM   #13
'79squared
'79squared's Avatar
Well I have the same problem. 2.5 drop spindles and 2" drop springs. Even with 2.5 drop spindles and 15/8's with a 4" BS my inner weights rub off if I turn to sharp. But also my caliper is maybe a 1/4" away from my rim so I would have to go WAY in with the weights if I did that option. So I have started to trim my a-arms but still need to go farther up the a-arm. I cant really see any problem with this as it is a cruiser only, and does not take any real abuse.
1979 SWB 350/350
'79squared is offline   Reply With Quote
Old 10-16-2012, 08:56 AM   #14
Hazieview
Well thanks for the feedback. I just dont like doing any grinding if I dont have to. I'll way all the suggested options.
Thanks again!
SB400 350th
