Brake problem
My dads truck the brake pedal is like pushing on a concrete wall, it's either all or nothing and we can't even press it down enough to trigger the brake light switch... What's wrong with it?
1965 c10 short stepside ![]() 1967 c10 fleetside 350/350 trans (my baby) |
Re: Brake problem
Take the master loose from the firewall to eliminate the pedal linkage. If thats fine loosen the line at the master to make sure the master is free. Work your way from there to elimate problems such as a dented brake line.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
60-66 Nut
Re: Brake problem
Is this manual brakes or power brakes? Original or aftermarket?
#4 | |
Re: Brake problem
Plan on looking over the whole system this weekend Posted via Mobile Device
