Old 10-16-2012, 12:36 AM   #1
tomdog77
5.7 vortec into my 77 truck?
Hello I'm new to this but was checking it out and see a lot of good help on here. I have a 77 pick up I've been building as an off road truck. The truck is pretty stout itself but after a recent trip to the hills I did like how my carbureted sb 400 cut out on the hills and rocks. I picked up a 5.7 vortec last year with the factory harness, computer and all. I would like to put the top end from it on my 400 since its a fresh block and runs strong. I know i need to drill the steam holes in the heads. Far as the factory harness can i use it? And just flash the computer I have? Anyone have some tips or problems I might run into?
tomdog77 is offline   Reply With Quote
Old 10-16-2012, 01:45 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: 5.7 vortec into my 77 truck?
The Vortec fuel injection system is a single injector system with a spider of tubes to feed each cylinder. While good for the trucks they came in, I would not go through the trouble of swapping and programming one as a way to get EFI.
Your best bet is to go with a EFI intake that fits your motor. The Edelbrock Victor EFI is a good choice, but there are many other options as well.
From there, you can choose a computer to run it all. If you want to run factory GM, the LS1 computer can be adapted to older engines which gives you the LS1 coil pack ignition as well. http://www.eficonnection.com/eficonnection/default.aspx
There's also many aftermarket injection systems, and even the open source Megasquirt.
My advice would be to sell the complete Vortec 350 and all associated parts to someone who's looking for one. Take that money and invest in a good EFI system.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 10-16-2012, 01:57 AM   #3
y5mgisi
Second Chance Program
y5mgisi's Avatar
Dont forget about the conversion spider!
Original style top, upgrade style bottom,
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-16-2012, 03:24 PM   #4
tomdog77
It came out of a 98 Tahoe if I remember right. Yes thank you for the info on that upgrade
Old 10-16-2012, 01:54 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
First off let's figure out for sure which vortec you have first. Know what year the engine is?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-16-2012, 05:18 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Ok, any 96 later Vortec engine is what you want.
Slap on a dual plane intake, nice carb, distributor, and mechanical fuel pump. Swap the cam out for real power gains.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-16-2012, 07:33 PM   #7
y5mgisi
y5mgisi's Avatar
Google, L31 swap. An L31 is the motor your getting. There is a ton of info out there on them. I always Liked those motors!
Old 10-16-2012, 10:52 PM   #8
tomdog77
Thank you that helps! Yes I really like it as well. Had a 99 suv with one in it, it ran like a raped ape for years with little problems.
