Cutting door top/channel
You guys ever see anyone cut the top of the door to match the bed with the top off, and still be able to use the top? I would think the window would be the same fit all the way to the top yea?
Obviously there would be some door mods to be done. Pics?
Blazer Project |
Re: Cutting door top/channel
I never did understand why its like that. I figured they would have lined them up factory?
72 Blazer 4wd 72 Blazer 2wd 69 Blazer 4wd easy to take apart hard to finish. Ray of all trades master of none. |
Yea...it doesnt look like such a big deal to modify the channel so it can be cut and still have a top.
Blazer Project |
![]() Join Date: Feb 2012
What would you do about the wind wing window? Ditch it and go with one larger window?
![]() Join Date: Dec 2004
i think the window slide would show,its fairly close to the top..just something to consider
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
If you did that the window would come right up/out of the door. BUT!!...you could prolly have taller glass cut (it's flat). Hhmmm.....I reckon the door top would need a 1"+ "ledge" to keep geometry to the roof w/strip.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
great points.... I know there is a conversion to go single glass. http://www.youtube.com/user/OnePieceProducts
I suppose what Phat T said is the likely fix for this, make taller glass. I want to do a roadster again but want to have a chopped and removable hard top.
Blazer Project |
#8 | |
The top of the glass will have to be cut, or you just wont wind the window up all the way. Which is exactly what you want
#9 | |
I guess I cant suicide the doors if I do this...oh well.
Blazer Project |
As I think about this again....will taller glass fit in the door and be concealed when rolled down? Remove the bottom stop and use power I guess.
I thought of that but again, as you stated, if you can modify the arm, it might work. I have an extra door....I will try it on that door and mock up something that might work like electric. I Will keep you informed.
Blazer Project |
Do you have any info(thread link?) on the blazer in the pics? Those are the wheels I want!
I think the door mod would be pretty cool with the wing gone.It would really clean up the lines the step has always looked out of place. Or you could just raise the bedsides and tailgate to match....and chop the top! ![]() |
Just these...
Blazer Project |
It's alsways something.....
![]() Join Date: Nov 2008
Another cool alternative would be to fab a piece that goes on the bed rail (attaches same as the top) that makes it the same height as the door.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
#15 |
SKINNY TIRES RULE!
I've seen a few of them cut and most are turned into roadsters without side windows. The one piece windows don't work in the blazers from what I've heard/read because there isn't any support when the window is half way down. Also, you'd have a funny door frame sticking up when you remove the vent window. Cutting them can look odd where the door meets the window frame too. You need to either cut at an angle to match or fab something for the corner. I'd think that putting a modern review mirror in the corner that has a window channel in it would solve the visual and the issue with the window not having support.
I've also seen a few extended bed rails. Most that I've seen are padded or wood. If you add bed rail extensions, you'll have a sudden drop at the tail gate, so you may need to add a tail gate extension too. Either of these options add challenges to getting a hard top back on. Bed/Tailgate extensions can be removed. If they are removable, they won't have the seamless factory look.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
