10-21-2012, 09:38 AM | #1 |
What socket for 4x4 service?
Hi guys. I just picked up an 86 for my winter truck and need to replace a ball joint. What 4wd socket do I need to get the hub apart?
Thanks in advance! |
10-21-2012, 09:51 AM | #2 |
I know the pieces fit
Re: What socket for 4x4 service?
It's a special deal for that truck, I don't think I paid but a few bucks for mine. But it's listed as a front hub socket for 73-87 4x4 GM trucks.
10-21-2012, 09:55 AM | #3 |
Would this be a common auto zone/advance/napa tool?
Posted via Mobile Device |
10-21-2012, 10:02 AM | #4 |
Moderator
They're easy to find. I think they're called "Spindle Nut Tools". AutoZone might rent them.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
10-21-2012, 11:57 AM | #5 |
How many tabs are on them? I just rented a kit and none of them work
10-21-2012, 12:41 PM | #6 |
There are 4 rectangular tabs, did you take the hubs all the way apart to the spindle nut? there are is a small snap ring that you have to get before the hub can be removed
1980 K10 350/SM465 |
10-21-2012, 12:52 PM | #7 |
I have the snap ring off the end of the axle shaft and it appears there is a gear like thing that is slid on the axle. Does this need removed before the socket can be used?
10-21-2012, 04:40 PM | #8 |
Yeah those need to come out the actual nuts you want are a couple inches into the hub itself..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
10-21-2012, 05:47 PM | #9 |
Thanks guys. Got it all apart and new ball joint in.
10-21-2012, 08:06 PM | #10 |
I found out the hard way on how to work on these hubs. Luckly parts were cheap and plentiful and the tool could be rented though I was given one. Good luck and keep'em nuts tight. Check'em regulary.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
