10-21-2012, 05:58 PM | #1 |
DJM Drop 72' longbed
DJM 3" lower control arms
Cut 2 coils off front springs Removed bump stops 5" Flip kit in the rear DJM drop shocks all the way around |
10-21-2012, 06:33 PM | #2 |
Re: DJM Drop 72' longbed
that looks really good. I'm actually looking at a DJM lowering kit for my truck right now. How ironic for you to post that info and a picture as I'm looking at there site.
10-21-2012, 07:02 PM | #3 |
10-21-2012, 07:15 PM | #4 |
Old member
Looks good man and it's a LWB to boot!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-21-2012, 07:23 PM | #5 |
anyone using these lower control arms with drop spindles?? I have a set of 2" drop belltechs and would love to use these control arms too.
Truck looks great man. Can't wait to get mine dropped.
'69 LWB C10: SB350 .060 over @10:1, Comp280 cam, 2800 stall, TH350, 4.11's. Want 6/6 static drop. "If at first you don't succeed, failure may be your style." |
10-21-2012, 10:45 PM | #6 |
How much did all that actually drop the front?
I was looking at there 2-3 inch lowering kit and I'm not sure if that means 2-3 inches lower all the way around or if its 2 inches in the front and 3 inches in the rear. Maybe you could possibly help me since you ordered from them as well. |
10-22-2012, 03:58 PM | #7 | |
The rear was supposed to lower about 5" but I think it's closer to 7". Here are some pics of the factory ride height, the drop before I cut the springs and the drop after cutting the springs. |
10-22-2012, 07:43 PM | #8 |
67-72 parts collector,…
Your truck looks good with this stance,... but how close are the front (DJM a-arm) "spring pockets" to the ground?
