10-23-2012, 09:04 PM | #1 |
Soft or Hard?
Now that I have your attention. I have a modified 250. Flat top pistons, decked block .025 and a Comp Cam. It is ported to match the gaskets. The HEI I have is bone stock from the junk yard. I have been told I need a Soft Vacuum Advance. How does one tell it they have a Soft or Hard advance? Or is the best way to go is an adjustable advance?
Thanks for any info. |
10-24-2012, 09:21 AM | #2 |
Re: Soft or Hard?
I always use a mid-70s big block chevy vacuum advance can-it limits the advance-it has less travel. It's a pretty obvious difference once you have the two side by side. Not sure if they fit the six HEI but I think they might be the same.
10-24-2012, 11:35 AM | #3 |
Re: Soft or Hard?
Use a G.M. HEI with a soft spring vacuum advance can PN (1973691)
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
10-24-2012, 06:37 PM | #4 |
Re: Soft or Hard?
Thank you Rich. The local O'Rileys had one in stock and there is a large difference in the way they react. Now for one more question. The distributer has about a .25 inches of vertical play. PO installed so I have no history. What is the end play supposed to be and Where can one get the required shims? OK that is two questions.
10-24-2012, 11:59 PM | #5 | |
Re: Soft or Hard?
10-25-2012, 11:37 AM | #6 |
Re: Soft or Hard?
Rich, Thanks for the link. I am headed to the pick - n- Pull this afternoon to see about another HEI distributer and take the best parts to make one good one. Again thanks for the for the help.
10-24-2012, 07:22 PM | #7 |
Re: Soft or Hard?
Having the distributor blueprinted and the proper centrifical(sp?) advance setup is equally important.
