10-24-2012, 07:41 PM | #1 |
Early 78-83 Intermittant wiper switch and relay
I originally picked this up hoping to find a way to make this work in my 77. I was actually lucky enough to find the UBER rare 77 only intermittant set up so I no longer need this. This is untested but came of a clean truck so there is no reason it shouldn't work. It includes the harness to the relay or whatever it is called. Price is $50 shipped within the USA.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
10-25-2012, 09:02 PM | #2 |
Re: Early 78-83 Intermittant wiper switch and relay
Any chance you figured out how to wire this up in the 73-77 trucks ?
10-26-2012, 12:40 AM | #3 |
I never got that far. I do have a nice long length of the pig tail included if you want to give it a shot.
11-01-2012, 10:03 PM | #4 |
ttt
11-13-2012, 09:17 PM | #5 |
ttt
11-14-2012, 09:31 AM | #6 |
Junior Member
The wiper motor is different in the 73-77 trucks.
I let my 16 year old son drive my every car that I own. I don't let him drive my truck. A man has to draw a line somewhere. |
05-15-2013, 05:31 PM | #7 |
ttt
05-15-2013, 08:16 PM | #8 |
What does the 77 switch look like? have a pic?
05-15-2013, 08:20 PM | #9 |
It looks almost identical except it has textured black instead of clear lexan
05-15-2013, 09:31 PM | #10 |
Do you know if this switch can replace a bad switch in a non-intermittent '79?
Posted via Mobile Device |
05-16-2013, 08:40 PM | #11 |
That setup should be plug and play for 78-84
05-16-2013, 09:26 PM | #12 |
Hey 1774,
I'm interested in the relay but I'm waiting on you to send me some pics of some headlight bezels (I sent you a PM) so maybe we can work out a package deal. Please send some pics of the bezels. Thanks! Posted via Mobile Device |
05-22-2013, 06:21 PM | #13 |
ttt
06-25-2013, 03:29 AM | #14 |
I got on my -77 an wiper motor from an -85 there I had to cut of the connection ball and weld it on the -85 wiper arm. I also got a wiper switch and the electronic box of an early -82-85 something and wired it all together. I can take pictures of the actual wires if you want to.
06-25-2013, 12:55 PM | #15 | |
06-26-2013, 06:22 PM | #16 |
Yes that is correct I had to weld that little ball from the 77 assembly on to the 85 wiper motor arm. They where different sizes, and it was easy to do that. I just hand filed the ball's weld off from the back of the 77 wiper motor arm.
I can take pictures of the wiring in a couple of days. Sorry about my last post I was tired and I had to think how I did it+ english is my second language. |
06-27-2013, 12:49 AM | #17 |
That is great info. I look forward to the pictures of the wiring. Thanks for taking the time to respond.
06-27-2013, 06:54 PM | #18 |
I got under the dash board tonight and realised years past and this is a good way to document how I did it.
Firewall -77........................................-85'ish wiper motor Dark blue------------------------------------Light blue Yellow/black---------------------------------White Tan (white?)/black--------------------------Purple Light blue------------------------------------Grey (two cables) Now to the cables under the dash -77 wires............................................wiper switch WITH the control box and cables! +power run to separate windshi. pump and back to------------------pink Black------------------------------------------Black Here I have also a cable run to an little switch on the signal -------------------Signal thingy Black/white-----------------------------------Purple Light blue-------------------------------------Grey From here also the second cable goes to the signal---------------------Signal thingy Dark blue-------------------------------------Black/Blue Grey from bulb from the older wiper switch--------------------------Second Grey And also you have to cut a little in the metal where the newer switch will go in. With my switch on the signal I can just touch it lightly and the wipers will go ones even if the switch is not on, perfect if you get water from oncoming traffic after rain or at start up in the morning. |
07-26-2013, 01:05 AM | #19 |
ttt
09-19-2013, 04:01 PM | #20 |
I will take it if you still got it. Reply here or send me a pm. Thanks
09-19-2013, 04:26 PM | #21 |
I do still have one. I will send you a PM with me email address and details.
09-20-2013, 11:32 AM | #22 |
Thanks Jeff. If the other switch you have comes with harness and everything as in your picture above I will take it. I sent you an email yesterday also.
09-27-2013, 12:22 AM | #23 |
I was finally able to do some checking and I do still have a pigtail harness with about 8" or so of wire. I didn't see a part number on it.
09-21-2013, 07:59 AM | #24 |
1774btcrew, is there a part number on that switch pictured? i been trying to find one
