Old 10-25-2012, 02:08 PM   #1
The Blue Pig
Thread Wizard Since 2002
Original configuration of a 72 K20
Hey guys, just had a quick question. What would have been the standard differential type/gear ration configuration on a 72 K20? Are the 72's more or less desirable than other years? Not much of a 4x4 guy...
--70 C-10 Longbed
--71 C-10 Longbed
--72 K-20 Longbed
--74 C-10 Shortbed
--86 Toyota Tercel (His Driver)
--05 Chevy Trailblazer (Her Driver)
The Blue Pig is offline   Reply With Quote
Old 10-25-2012, 06:06 PM   #2
b454rat
Re: Original configuration of a 72 K20
44 front Eaton rear, could be a Dana 60, don't know why one over the other....ratios, just guessing but 3.73 up to 4.56s...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 10-26-2012, 01:09 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Also just guessing, 4.10 ratio may be the most common on a '72 K20. I personally prefer '71 or '72 over earlier trucks because they came with front disc brakes. Not a huge deal because obviously those could be upgraded on an earlier truck. Also, I think frames were different on '67s so replacement springs are harder to come by.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-26-2012, 10:36 PM   #4
I believe the automatic K/20s got 4.10 and 4spds got 4.57s. Front axle was Dana44 and rear was HO52 (Corporate). GMCs came with Dana60 rears and were 4.11 automatic/4.56 4spd. I think 71 & 72s are equally most desirable due to having the most improved drivetrain
Old 10-27-2012, 11:12 PM   #5
rsmarr1982
rsmarr1982's Avatar
i just bought a rolling frame from a guy that he said had a eaton 72 rear which he said is one ton. any truth to this?
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 10-27-2012, 11:21 PM   #6
rsmarr1982
rsmarr1982's Avatar
its a 4x4 so would that make it a k30?
Old 10-27-2012, 11:50 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
There were no K30s built in 1972. It may be a K20 frame with an HO52 differential, which is same as an HO72 except for brakes. There *might* be a difference in axles, but the pumpkins are the same. Some HO52s had the load bolt and some did not, while all HO72s had it.
Edit: IF it's a 2wd frame converted to 4x4..... I'm pretty sure C30 frames had larger (taller) c-channels than C/K10s or C/K20s, so you could measure & compare to a known frame.
- Mike -
RIP El Jay
Old 10-28-2012, 07:46 AM   #8
SS Tim
SS Tim's Avatar
Here is the powertrain chart.
SS Tim is offline   Reply With Quote
Old 10-27-2012, 11:49 PM   #9
RPIcka
I believe the Eatons were 1 ton rated
RPIcka is offline   Reply With Quote
Old 10-30-2012, 08:32 PM   #10
No 30-series trucks were built with 127" wheel base. The only Fleetsides were Longhorns.
Old 12-14-2014, 08:57 PM   #11
coopdog
coopdog's Avatar
My original browsher says the ratios
coopdog is offline   Reply With Quote
