10-27-2012, 06:01 PM | #1 |
Little help in Az, Please
I am looking for New brake lines in Phoenix, Az. for 1971 C-20 307 eng. I need the ones from the Master cyl to the proportioning valve. My pro valve is mounted on the front cross member. Any thing will help! Nick
10-27-2012, 06:09 PM | #2 |
Re: Little help in Az, Please
Get some brake line and fittings. You will need a flaring tool, make your own.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
10-27-2012, 06:10 PM | #3 |
If you dont want to make your own, try grunions out on cave creek rd or az pro performance in Queen Creek, they should have them or know someone who does.
Weev- Posted via Mobile Device
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
10-27-2012, 06:38 PM | #4 |
Am I missing something here? The 71 stock has front disc brakes and the conbination valve is on a bracket just below the master cylinder. Did this get removed or relocated to the front cross member? Does it have/need both front and rear M/C output lines running to it? Then have the rear brake lines extending from it as well?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
10-28-2012, 02:42 AM | #5 | |
10-29-2012, 04:43 PM | #6 |
I nthink that this set upm cam from a newer pickup its the same as my 76 i had.
10-29-2012, 04:49 PM | #7 |
I drive a 69, Drum/Drum.. I was in need of a new line from the master to the distribution block right under it, probably 4 inches at the most. Couldnt find one anywhere, so I just bought the supplies and bent my own. It was very easy with some practice. Way easier than trying to track one down haha.
10-30-2012, 05:42 AM | #8 |
Ya I am planing on moving it back to where it should be and make my own from SS lines. Heck now that I got a new MC, I have 3 old ones and 2 prop vales to play with. I will let you know wher i get the SS tubing from(hopefully local) Thank again guys for the imput!
Nick |
10-29-2012, 04:48 PM | #9 |
That is most definitely odd. I have never seen one mounted there before. I would suggest mounting it where it should have been from factory.
