Old 10-27-2012, 08:36 PM   #1
Biggs1966c10
66 chevy rear sway bar
I am wanting to add a rear sway bar to my 66 chevy short wide bed it has 4 inch lowering springs in back and 2 and a half drop spindels in the front will a stock sway bar kit work?
Biggs1966c10 is offline   Reply With Quote
Old 10-27-2012, 10:08 PM   #2
Shooters_7
Re: 66 chevy rear sway bar
What are you using your truck for? Did you update your trac-bar when you lowered your truck? Check this setup out: http://www.porterbuiltfabrication.co...e-Trac-Bar-149
Conner
1965 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=535078
Shooters_7 is offline   Reply With Quote
Old 10-27-2012, 11:01 PM   #3
Biggs1966c10
just driving nothing special no i used factory trac arm
that set up looks good i would just like to minimize body roll with rear sway bar what do you think?
Old 10-28-2012, 01:18 AM   #4
ol_skool_chevy
ol_skool_chevy's Avatar
go get a front and rear sway bar out of a "F Body camaro be sure to get the mounting
best add on i ever made cost me about 18 bucks at pick and pull
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-28-2012, 08:34 AM   #5
kevinc
kevinc's Avatar
Interesting. What year F-bodies will fit the rear?
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 10-28-2012, 10:21 AM   #6
bama63
bama63's Avatar
try this....http://www.low69cst.freeservers.com/CamaroBar.htm step by step with instructions and uses 82 and up camaro rear sway bar
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 10-28-2012, 03:41 PM   #7
Shooters_7
Pics of a sway bar added to the rear.
Conner
Old 10-28-2012, 06:00 PM   #8
Biggs1966c10
thats different from what i have seen most are over rear end?
Old 10-28-2012, 06:18 PM   #9
Shooters_7
I was reading through other builds and saw this. I don't think there is any specific way to mount these sway bars as long as the end state is the same.
Conner
