10-29-2012, 09:52 PM | #1 |
My jimmy (new here)
My 87 jimmy, it's my first vehicle
Don't have much info on it except that it has a newish crate motor(350) ..under 50k miles? and that it has over 180k on the vehicle its self Just got new rims and tires on it Hoping to get it painted and the few rust spots/dings taken care of ...can't decide on color yet? any suggestions..something that goes well with red interior. ..then a 4' susp lift..maybe even a 6' |
10-29-2012, 09:57 PM | #2 |
Re: My jimmy (new here)
also is it me or does the front bumper sag? i will have to check it out sometime this week when i get some time
10-30-2012, 09:26 AM | #3 |
white gets my vote. yes it does look like its nosed down a bit.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
10-30-2012, 11:25 AM | #4 |
Looks like a good, solid starter truck.
Can't wait for the 4 foot - 6 foot lift.....that's gonna look sweet!! (Jk) Seriously though, once you go to a 4" or 6" lift, it starts to complicate things and bottom line, cost a lot more money to roll properly. Axle strength, pinion angles, driveline angles, U-joint angles, vibration, steering squirly, etc. Do your research before jumping all in. With that said, I love the truck and I've always been partial to white as well! I bet you could adjust that front bumper too. Maybe it's just a little loose.....
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
10-30-2012, 08:37 PM | #5 |
>.< i knew that didn't look right
True maybe something under a 4" i just want it a bit higher and go with some with 33's or 35's I'm probably gonna go with pearl white |
10-30-2012, 08:55 PM | #6 |
33's to 35's are a good range. I have 35's on a 2.5" lift. As long as you are not wheeling it hard and be gentle, the tires don't really rub during normal driving. If you wanted it to be safer, you could do 33's no problem.
Where I'm getting at is even at 2.5" lift, I had some driveline vibration. Not the most idea solution, but I dropped my T-case 1" and that took care of it. But some say that's not the best solution. The best is a whole new drive line and possibly a CV type joint. AKA....bigger dollars. Here is mine.....
10-30-2012, 09:36 PM | #7 |
Yeah thats the kind of look im going for. Nothing to crazy
Thanks for the info i will look over it Very nice k5..i can't wait to get mine painted i think she will look 100x times better |
10-30-2012, 10:59 PM | #8 |
Chevys Kick A$$
Hey welcome to the best board around from MT! Sweet looking Blazer nice find looks super clean from here The front looks a little bit lower for sure. New lift should fix that. Nothing looks better then a lifted K5 with some meaty tires under it
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
10-31-2012, 10:20 AM | #9 |
Thanks, it is for the most part, just minor rust issues and a ding on the other side near the tail-light
10-31-2012, 10:25 AM | #10 |
I know the pieces fit
Both of those are good looking trucks. A 2.5 to 3" lift over 33x12.50's is just about perfection on a K5. Although 35's sure do look good.
10-31-2012, 01:17 PM | #11 |
Yeah they do look good like that
