Old 10-30-2012, 02:43 AM   #1
Jedipartsguy
Jedipartsguy's Avatar
Manual to power doors
I picked up an 84 c-10 for parts and it came with a set of perfect power window doors. My door are manual and pretty rusty. What is involved in that conversion. The whole complete harness is there in the 84.
"Hank" 78 k10 6" lift 33's, good wrench 350 sm465 np205
Jedipartsguy is offline   Reply With Quote
Old 10-30-2012, 03:03 AM   #2
frog210
Re: Manual to power doors
just swap doors and get the wiring harness
run a line to the battery with a inline fuse 10g or thicker
also if it has power locks dont forget the relay by the fun pedal
you also need to make holes by where your doors mount to run the wires
i used a 1 or 1 1/4 inch hole saw bit to make the hole
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 10-30-2012, 06:19 AM   #3
S10Fan
Old Heap Driver
Just grab the complete harness, everything you need will be right there. It's a tedious process (getting all the wires) but well worth it when everything works as it should. I grabbed a harness for mine and ran everything then taped off the ends in the doors. If you follow the donor harness from the doors you'll end up with everything you need from the doors to the fuse panel. Mine is still all manual but ready to go power when I get around to it.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 08-15-2014, 05:24 AM   #4
slimneverdies
slimneverdies's Avatar
Anyone have any pics of the harness going to the fuse box? Just about to make the conversion and have everything except the directions to hook it all up... Does the fusebox have to be year specific? I have 91 doors and harness but a 77 fusebox...
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
