11-02-2012, 10:05 PM | #1 |
Replacing the vent window weatherstrip
Hey guys is replacing the vent window weatherstripping difficult? I dont know why im intimidated by this, maybe its the rivets. I see CLassic Parts has the entire vertical window assembly including the vent window and weatherstripping as one unit. Kinda pricey, but maybe worth it.
http://www.classicparts.com/1955-59-...info/18-292L/# Let me know if its a big deal to deal with the weatherstripping. Mine is original, hard as a rock, and the vent windows are flopping around like dogs ears. Need to do something about it... Thanks, Mark |
11-02-2012, 11:25 PM | #2 |
Re: Replacing the vent window weatherstrip
Mark it not as hard as it looks, just take one a part at a time. and you will have to put a rivet back it where you have to drill out the stock rivet.. took some off a '51 and had them power coated and then rebuilt them and they came out like new...
11-05-2012, 01:01 AM | #3 |
Mind if I ask what powder coating a pair ran you? I wouldn't have thought of doing that but it is a great idea. Did you powder coat them black? Chrome? or Other?
11-05-2012, 01:11 AM | #4 |
Dan i don't know what it cost to power coat them as i had a ton of stuff done at the same time.. but i don't think it would be that much and it holds up much better than paint.. i had them done in semi gloss black..
11-04-2012, 01:35 PM | #5 |
i have done several of these -parkwood is right about the rivits - you can buy the rivits and the tool from truck parts suppliers - after you get the rock hard rubber out and all the rivits redone - use soapywater on the new rubber - should slip right in
good luck |
11-04-2012, 11:30 PM | #6 |
Thanks for the tips guys. Regarding drilling out the old rivets, what size drill bits to use? I assume I have to be careful with this step as if I use too large a bit, the new rivets will have too much slop and I will have a real mess on my hands.
11-05-2012, 01:35 AM | #7 |
i believe the last pair i did ran $120 for the pair - i also had them blasted clean and also went w/ the semi gloss black .
yo 62 i believe i used a 1/8 inch drill bit - use a new bit and take your time . good luck |
