Valve adjustment SBC
Ok Gents,
I have a SB 350 with hydraulic lifters and I'm replaing the stock rocker arms with steel roller rockers. Do I need to torque the rockers to a certain level or is there a different way? I have never done this and want to learn on my own so any advice would be very much appreciated. Thank you. Posted via Mobile Device |
#2 | |
Re: Valve adjustment SBC
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
Thanks for the help, Sounds pretty strait forward.
![]() Join Date: Jan 2001
You adjust the hydraulic the same as you would a flat tappet. The only difference is that you give them a 1/4 turn preload after you get zero lash on the push rod. It is recommended that you only do an 1/8 of turn if you are going to be running high rpm's more often than not, more towards a race application than street application.
This link says to do it after the engine has been running, but you will be fine doing it with out running the engine. Though most of the time it is recommend to do readjustment after you break the cam in after running the engine at 2500 rpm's for 15 minutes. This is one of the better break downs of the adjustment I have found that explains pretty in-depth about it. http://www.centuryperformance.com/va...procedure.html I suggest just doing the 1/4 turn for preload after zero lash. It has worked just fine for me thru out the years of doing this with no failer.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
Not knocking anyone, but I've never got the pushrod spinning method to work...however...
It's a simple deal. The lifter HAS to be on the base of the cam, NOT on the lobe, when cam lobe is pushing the lifter up to open the valve. Tighten the rocker down until there is NO clearance or jiggle between the rocker and top of the valve stem. Then tighten the rocker nut another 1/4-2/2 turn. That's it....You just have to make sure you are NOT campressing the plunger in the lifter, when taking up the clearance out of the rocker/valve area... |
#7 | ||
"I ain't nobody, dork."
1/4 turn is for a higher lift radical cam. Stock is one full turn. Depending on your cam I'd say 1/2 to 3/4 turn.
Personally I've always used 1/2 turn on my performance engines, and 3/4 turn on a more mild stockish build. Gary
i'd think if you never done it and dont have engine experience a service manual might b a good investment for you or at the very least a daytrip to the library
If you like wrenching on small blocks, this is a good book to have, "How to rebuild your Small Block Chevy" by Dave Vizard. It's got some good info.
#10 | |||
Gary
#11 | |
AND when I was younger, a couple of my buddies built several engines... I got to learn from their mistakes... ![]() Most of the stuff (my opinion) on 40+ year old cars, mechanically is visual stuff, brakes, suspension, even electrical, you can see what you are working on, and don't have to visualize what the problem might be, you can see it, NOT so w/ modern computer cars........ |
