Old 11-03-2012, 12:44 AM   #1
vjjack04
vjjack04's Avatar
SBC engine running way too cool
Guys,
I have a Summit Racing radiator (rather small) in front of my SBC and a high volume water pump and no shroud.....the thing is running about 165 degrees most of the time.....oh and I have 20 inch electric fan.......what can I do to get the engine to get a little hotter and stay around 200 degrees? Thanks.
vjjack04 is offline   Reply With Quote
Old 11-03-2012, 05:58 AM   #2
jjzepplin
jjzepplin's Avatar
Re: SBC engine running way too cool
Do you have a thermostat? They keep the water in the engine longer heating it up more..
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-03-2012, 07:07 AM   #3
vjjack04
vjjack04's Avatar
Thanks, yep. It opens and the thing goes back cool.....
Old 11-03-2012, 08:20 AM   #4
Highsider
Highsider's Avatar
Good reading using the search feature at the top:
http://67-72chevytrucks.com/vboard/s...d.php?t=468487
http://67-72chevytrucks.com/vboard/s...d.php?t=361473
Highsider is offline   Reply With Quote
Old 11-03-2012, 11:44 AM   #5
_Ogre
_Ogre's Avatar
fan and radiator have nothing to do with a motor running too cool
that is solely the thermostat's job
first i'd check the accuracy of your gauge using a infrared thermometer on the thermostat neck
you can also check the accuracy of the thermostat by hanging it in water by a thread stuck in the opening part of the thermostat
heat up the water and use a meat thermometer to check the temp when it drops off the thread
or just buy a new thermostat
shop air compressor timer
Old 11-03-2012, 12:21 PM   #6
mknittle
mknittle's Avatar
Yeap!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-03-2012, 12:55 PM   #7
vjjack04
vjjack04's Avatar
Ogre, I am going to buy a new thermostat...then, I will let you know....
Old 11-03-2012, 12:22 PM   #8
mknittle
mknittle's Avatar
did you get it at napa? if so I think I see the problem!
Mark
My GMC build.
Old 11-03-2012, 12:48 PM   #9
Highsider
Highsider's Avatar
Alright, I will bite. Tell me the what's-up on a NAPA thermostat.
NAPA is my best (only) choice out here in the boonies.
Old 11-03-2012, 10:59 PM   #10
_Ogre
_Ogre's Avatar
if both thermostats show low temps...
i'd say your gauge is wrong/bad
you do realize that tf gauges have no numbers for a reason
they give you a range and feel for temperature
Old 11-04-2012, 10:23 AM   #11
solidaxel
solidaxel's Avatar
I have had very good luck here in the desert with a Robert Shaw high flow 180* thermostat and a 190* fan switch in the head between # 6 & 8 cylinder, the fan will cycle on and off if it gets to 190+ and will turn off at the right temp 180*
Don's hot rod shop should have everything on the shelf, the next time you are in town!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-04-2012, 10:12 PM   #12
vjjack04
vjjack04's Avatar
interesting...I am not using the factory gauge.....I have an decent aftermarket gauge...I do think I need a new thermostat and a better electric fan sensor......
Old 11-05-2012, 07:05 PM   #13
_Ogre
_Ogre's Avatar
fan sensor has nothing to do will cool running
when you turn the ac on the fan comes on in all new cars to pull air over the condenser
problem is probably your thermostat
Old 11-05-2012, 09:48 PM   #14
mr48chev
mr48chev's Avatar
Boy howdy, wait until I tell the guys on the HAMB that I know someone who has a sbc in an old truck that runs too cold.
All joking aside I'd run a 180 thermostat if I was down there where getting enough heat out of your heater wasn't an issue when you are out driving the truck in 10 degree weather.
If the gauge is electric it may be reading wrong. My best friend could pull the radiator cap off his walker radiator and not get scalded when the temp gauge read 265 (it went to 300 but I don't know why) when the Walker rep put a temp gauge in the neck it read 170 while the gauge was reading 265.
If things check out and it's still running cooler than you want put a 195 thermostat in it which is standard for a lot of 70's and 80's Chevys and what I run in my 71 GMC with a 79 350. And I didn't work on my heater today and hope it doesn't turn cold this week.
