11-03-2012, 01:04 PM | #1 |
1973 454 lwp complete front accesory drive pulleys brackets
I pulled a 454 out of a 73 chevy truck but I am putting it in a 72 c10 and already have the Swp set up so I don't need the lwp set up.
I have all parts needed for ps, alt and wp. The truck originally had A/C, so it has the correct pulleys for AC, butthe brackets and compressor were removed before I got the truck. This is a non hydro boost set up. Here is what is included: 2 brackets and spacer to mount alt on pass side Ps pump and brackets Single groove upper wp pulley 3 groove lower pulley (I haven't pulled these but it looks like it is 2 pulleys stacked) All bolts to mount everything above. $200 shipped to lower 48 for everything above I will include the used LWP and alternator for an additional $50 (mainly due to shipping weight) I also have the stock cast iron intake manifold bare $75 shipped Stock stamped steel vc's $50 shipped stock cast iron exhaust manifolds, no cracks, exhaust pipe cut with torch approximately 8-10", flange bolts undisturbed $150 shipped Aftermarket flex fan, spacer and bolts that positioned the fan 1/2 way out of the factory 4 row shroud $40 shipped (sorry the radiator and shroud are already sold) I forgot to take a photo before I started taking it apart. I will post photos later tonight. Last edited by WIDESIDE72; 11-03-2012 at 01:39 PM. |
