11-03-2012, 06:00 PM | #1 |
will these go right in the place of my old ones?
11-03-2012, 09:03 PM | #2 |
Re: will these go right in the place of my old ones?
Sawzall or cutoff wheel
Posted via Mobile Device |
11-03-2012, 10:09 PM | #3 |
Proud owner of a 55.1 AD
I used a spot weld cutter to remove mine. Takes awhile, but makes putting on the new rocker a little easier.
11-03-2012, 11:21 PM | #4 |
Go easy at it! Restoring an old truck is like peeling a rotten onion, you just keep taking away the bad layers,until you get to the good stuff....drill the spot welds, and carefully pull back the bad stuff
11-04-2012, 07:46 AM | #5 |
where are the spot welds? and yeah i know i need to take my time for sure. i cant rush it.
11-04-2012, 09:19 AM | #6 |
If you grind the paint lightly, they will show up...if its all rusty, try a screw driver to pry it up,if it doesnt move, there is a spot weld there
11-04-2012, 01:57 PM | #7 |
11-04-2012, 10:23 PM | #8 |
thanks for the help!
