Taillight Issue
My taillights and brake lights no longer work, but both turn signals and hazard lights/emergency flashers still do.
I have checked the fuse, it's good. What other things could cause this? (Possible hint: I installed a relay for my hazard lights, as there was not one on the fuse box when I bought it. In doing so, I detached the ignition wire from the fuse box accidentally, so I put it back, and later noticed an orange wire hanging with no connector on the end. There is no connector that has fallen off or become detached from the orange wire, it was just never there. The way the wire hangs it almost looks like the previous owner just shoved it into the connector with the ignition wire, but that doesn't make sense to me.) |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Taillight Issue
That's your problem. The orange wire goes to the brake light switch and the headlight switch. It connects to the fuse panel as shown in this diagram.
Then it goes to the head light switch as shown in this diagram. This is the back of the fuse panel and the orange wire attaches like the rest. If only one orange wire is loose then the dome light might still work. You might be able to solder it back to the rivet connection.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: Taillight Issue
THANK YOU! Seems simple enough. I'll reconnect it when the sun rises again!
Re: Taillight Issue
I should have also asked: If I hook up the orange wire for my taillights to the ignition wire will that also work for the time being?
#5 | |
Msgt USAF Ret
Re: Taillight Issue
The end of the stop/turn/tail fuse on the fuse panel would be the best place if you can make a good connection. I have to ask if the orange wire that's loose is not a hot wire and if so then you'd need to connect it to the end of the fuse that's cold when the fuse is out so that the orange wire is fused.
Re: Taillight Issue
I connected it the the ignition unfused terminal and placed an inline fuse on the wire, which made my taillights work but not my brake lights.
I'll try hooking it to the stop/turn/tail fuse tomorrow. |
#7 | |
Msgt USAF Ret
Re: Taillight Issue
Looking at the diagrams I posted above if you can find the three orange wires and trace them, you will see that they go to the headlight switch for the tail lights, to the stop light switch for the brakes, and to the dome light. The turn lights operate with the brake lights and the flasher wire to the turn signal switch but that is another circuit for discussion with another problem than yours.
