Old 11-05-2012, 06:22 PM   #1
barrykathy
how to calidrate 1971 speedometer
i have 1971 GMC 1500 6 cyl. the stock rear end 3.73 i changed to a 3.07 now the speedometer is off by about 15 MPH is there a way to calibrate to speedomete
barrykathy is offline   Reply With Quote
Old 11-05-2012, 06:33 PM   #2
hayhauler71
hayhauler71's Avatar
Re: how to calidrate 1971 speedometer
You need to change the speedo drive gear and the driven gear in the tail shaft of the trans. There is also a few companies that sell transducers that go on the trans that will change the speedo reading but dont recall the companies name
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-05-2012, 06:54 PM   #3
geezer#99
geezer#99's Avatar
http://www.transmissioncenter.net/sp...____va.htm#350
Old 11-05-2012, 08:17 PM   #4
blasher
blasher's Avatar
I just fixed the same problem on my truck. I used a GPS to confirm how far I was off (read 48 when traveling 60), then I bought a vintage Stewart Warner speedometer correction gear box on eBay for $30. I got one that was a 1.250 ratio (48 X 1.250 = 60). Real simple to install and works like a charm. It was a rewarding fix. You can buy a new reproduction one for twice the price. Since mine was used I opened it up and cleaned out the old grease and re-greased it. The innards and brass gears were in great shape. It's a quality unit.
blasher is offline   Reply With Quote
Old 11-05-2012, 08:22 PM   #5
69GWC
Thats about how far off my 69s is after installing 33s, 50mph =65...
69GWC is offline   Reply With Quote
Old 11-05-2012, 08:23 PM   #6
Tim Christian
Tim Christian's Avatar
Is it a automatic or manual?
Tim Christian is offline   Reply With Quote
