11-06-2012, 11:45 PM | #1 |
Aftermarket Disk Brakes?
Hello All.. I have a 1983 K20 looking to upgrade my brakes. I'm looking for bigger disk brakes up front and a conversion from drum to disk in back. Anyone know of a company that does this? Thanks much
1983 K20 Scottsdale |
11-07-2012, 12:21 AM | #2 |
Re: Aftermarket Disk Brakes?
^_- Im interested too
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
11-07-2012, 02:36 AM | #3 |
In the Forgotten far North.
Just got my rear disc conversons from http://www.blackbirdscustomtrucks.com/ last weekend. Gonna get them installed at the end of the month.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
11-07-2012, 04:06 AM | #4 |
Ok, here it goes... you can turn your hubs down just a hair (1/16") front and rear. Then a modern slide on rotor works. In the fron you could either run a 14" Dodge 3500 rotor from an 08 and in the rear a 13.88" dodge 3500 SRW rotor from 08. You would only have to fab up mounts for the callipers.
If you want to go even larger in the front (what I did, but on a dynatrac D60) is a 04 forf F550 rotor, redrilled to 8x6.5" bolt cycle and 08 F550 callipers. Those brakes are 14.45" front. HUGE. Will fit some 17" wheels but normally requires at least an 18" wheel. In the rear, I went with a complete 08 dodge rear setup with backing palte, OEM parking brake, etc. You have to fab up an andapter plate and weld that to the housing. The rear setup is not quite done yet, but the fron is and its great. I still need to swap the proportioning valve tpo a disc disc and also install the new master cylinder (form an 88 P30 motorhome). Then you will have OEM parts, nothing crazy custom and a HUGE improvement over the stock brakes! |
11-07-2012, 10:08 AM | #5 |
google big brake kits, there are many companies
11-07-2012, 11:52 AM | #6 |
Not for these old trucks though... maybe the 2WD halt tons, but not anything 3/4 ton and nothing for 4WD.
11-07-2012, 04:28 PM | #7 |
You might find something here:
http://www.getdiscbrakes.com/
1977 Chevrolet Scottsdale: 1979 Camaro Z2/8 http://www.nastyz28.com/forum/showthread.php?t=129623 |
11-07-2012, 08:04 PM | #8 | |||
Yeah I did that... Quote:
11-08-2012, 08:57 PM | #9 |
For? what it's worth i just up graded my 87 v20 with rear disc brakes. I installed a set of front stock calipers and rotors that i bought from Oreilly's along with a pair of brake lines of course, then i bought a nice set of backing plates for $65 shipped to my door. My brakes kick ass now. I have maybe $300 into the conversion. Something to think about.......
Posted via Mobile Device |
11-08-2012, 10:59 PM | #10 |
11-09-2012, 12:00 AM | #11 | |
Awesome Im going to give these guys a call first thing tomorrow!! Thanks
11-09-2012, 01:31 AM | #12 |
I got my conversion kit from www.diy4x.com. Have nothing but great things to say about the level of service and the quality of the parts. All told, I have $360 in the swap.
The second image shows where you would need to grind for clearance inside the wheel. My truck is a dually with 16 inch Alcoa wheels. |
11-09-2012, 04:34 PM | #13 |
Yes Ruffstuff is who i bought the brackets through. Very nice product.
