Old 11-08-2012, 10:24 AM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
Global West Suspension for C-10's
Has anyone seen this:
http://www.globalwest.net/c-10-chevy...obal-west.html
Complete front and rear suspension system with Coil Over shocks for 63-72 C-10 trucks. Uses the stock spindle and steering box up front, the rear has a Watts link to center the rear end. The pictures look cool, but the price for the front seems high compared to Porterbuilt and No Limit.
Again more cool options for us with C-10's!!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-08-2012, 07:05 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Global West Suspension for C-10's
Kinda cool.
Retains the stock steering.
I wonder if you gain any ground clearance?
Keith
Convert to disc brakes.
Old 11-08-2012, 07:08 PM   #3
lolife99
lolife99's Avatar
From their page,...
Global West’s new C-10 Classic Truck front suspension is simple to install and provides handling, tune ability, and lowers the ride height while still providing suspension travel. The new system directly replaces the stock cross member, upper and lower control arms, sway bar, and fixes any bump steer issues you may have had before. The stock spindles are retained and Global West provides aluminum steering knuckle arms in the kit that zero bump the steering geometry. Note: If dropped spindles are used, bump steer will have to be reset. The steering box (power or manual) and linkage is retained reducing costs and also frame modifications. Installation is a bolt on. That means no welding is necessary, hand tools will get the job done.
Tubular Upper Control Arms: The upper control arms are built out of 1.125 DOM tubing. Each tube is CNC mandril bent and precisely notched to welding jigs. The upper control arm provides 6 degrees positive caster and produces negative camber gain for superior handling and stability. The upper control arms are powder coated black and pre-assembled with Global West’s Del-a-lum bushings and offset control arm shafts.
Keith
Old 11-08-2012, 08:15 PM   #4
GEARBOXGARAGE
Yeah, we saw this about a month ago in an advertisement in Street Rodder Magazine. Would have really liked to share that info then, but we were getting ready to release our own G-TR Rear Coilover kit.
GEARBOXGARAGE is offline   Reply With Quote
Old 11-08-2012, 08:25 PM   #5
SCOTI
SCOTI's Avatar
That does not look like a C10 spindle...
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-08-2012, 08:30 PM   #6
GEARBOXGARAGE
The spindle in the pic is an A-body (chevelle) spindle
Old 11-08-2012, 11:45 PM   #7
aggie91
aggie91's Avatar
To me that spindle looks just like the ones on my drum brakes from my '65 C-10. The info does not really say which stock spindle the kit uses...
Karl
The LST Challenge:
Old 11-09-2012, 08:37 AM   #8
GEARBOXGARAGE
That is a possibility as well.....
Old 11-09-2012, 11:15 AM   #9
aggie91
aggie91's Avatar
Gearbox, where is Sturgis are you located. I have not been up there in awhile, but use to travel up there to visit Burr Oak Tool when I worked in the HVAC industry. Still have some freinds there. Do you ever eat at a steak place called Bill's (i think thats the name)...?
Karl
The LST Challenge:
Old 11-09-2012, 11:22 AM   #10
GEARBOXGARAGE
WOW! Small world, I actually work at Burr Oak Tool in engineering as my full time job. The Gearbox Garage is a small Hot Rod shop I'm trying to get going on the side. Yeah, Bill's Steakhouse is a great place to eat. That's a little east on the other side of Bronson. We are about 15 North of Strugis, closer to Centreville. Here's a link to our web page that we are building...
http://www.thegearboxgarage.com/
Good to hear from someone who is familiar with the area! What company did you work for when you would travel here?
Old 11-09-2012, 12:49 PM   #11
GEARBOXGARAGE
Will do! I work in the same group as Rocky...
Old 11-10-2012, 02:41 PM   #12
project 67 sub
project 67 sub's Avatar
That company is in my home town right along with no limit
project 67 sub is offline   Reply With Quote
Old 04-19-2013, 08:36 AM   #13
avarela321
As of Christmas 2012 I have received this suspension. I have not got to play with it yet due to school, Its going on a 1970 c10 step side that I am recreating with my dad, I have not received much info on it yet due to my studies which keep me away. First impression was nice, packaged well and everything arrived in good condition. Ill take photos of it when i get back home in a couple days. Its going to be a while before its on the truck but when i do i will be sure to make comments. I havent seen a test run or a video if any sort with a truck using it, but we do have global west products on my brothers monte carlo and the car is all the better for it, running almost 10 years, still looks brand new.
avarela321 is offline   Reply With Quote
Old 04-19-2013, 08:59 AM   #14
SCOTI
SCOTI's Avatar
Did you get the coil-over crossmember kit or the a-arm kit that utilizes the OE crossmember?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2013, 10:56 AM   #15
avarela321
to my knowledge there is only one kit for the front suspension. I just revised the website as well, and i only see one. the link states is c-10 classic truck suspension.
Old 04-19-2013, 12:37 PM   #16
SCOTI
SCOTI's Avatar
Yeah, I looked this AM too. Wasn't sure what/when you ordered.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
