![]() Join Date: May 2012
66 step pro street build
Starting the build on my 66 step.Try to keep up with pics as the build moves along.As they say on tv let the tear down begin.!! Should end up flat black ,slammed,with monster meat in the back,and a 540ci motor in the front.!!!
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
![]() Join Date: Oct 2010
Re: 66 step pro street build
Should be super sharp! Good luck to you. Anxious to see the build
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
Looking good so far can't wait see more
Specs on the motor? I'm drooling
![]() Posted via Mobile Device |
guna be nice. motor looks like the twin for my 84 dually..
The motor was in my race car,it's a gm 502 block bored 4.5.Ohio crank forged rotating assy.
I will have to swap the pistons out they JE 14.1 42cc dome.I will go with 10.5 11.00 cr pistons for the street.rhs alum heads 2.30 intake and 1.88 eh. ferria ss valves.lunait solid cam,738-756 with 292 dur. and 4/7 swap.Merlin x intake with a 1050 dom. carb.built it myself two years ago.Ran 5.60 in the 1/8 mile with a 2600 lb 76 camaro.Got tried of racing and wanted to get back to playing on the street some ,should be able to do both with the truck.!!!! Think i will leave the 12 bolt in it,unless I can find a good dana 60.I know some of the 67/72 trucks had a dana in them.The motor is all studded mains and heads with arp studs.I have some build pics of the motor if you would like to see.
#7 | |
60-66 Nut
Post 'em up, I'd like to see them
![]() Quote:
![]() Join Date: Nov 2010
Sweet!!! Should be radical for sure!!
LIFE IS SHORT HAVE FUN |
![]() Join Date: Mar 2005
Oh....I like where this one's going!! This is going to one serious machine.
I'm a big fan of Pro Street. All of the magazines have said for years that it was out of style, but not in my world. A nasty motor, fat meats in the rear, and a ground-hugging stance is my definition of a hot rod.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#10 | |
60-66 Nut
Same for me......
How much weight are you gonna have to plant in the back to keep that thing hooked to the street?
62 C10, LWB fleetside, 350SBC, Munie 4spd, |
Going to use coil over shocks in the rear i think,and if I can get a little weight transfer with the right set up in the front might work ok.Going for the WOW factor more than anything.!!Thanks for the brackets captain fab.!!Here are a few pics of the motor build.
Shocked at how clean this truck is.!!! No rust to be found any where,the guy told me it was garage kept and it shows.Every bolt came out with no trouble.WOW .!!!
Front of the cab,where the bottom of the front fender bolts up. ![]() Inside of the bottom of the front fender.!!!! no rust ![]() Another shot of the inside of the front fender ![]() Windshield cowl area.!! ![]() Pull the inner fenders and motor and trans tomorrow. ![]()
The engine looks great. Nothing like a big cubic-inch big block to get the job done. I couldn't help but notice that your Camaro was painted just like the old Reher-Morrison Pro Stock from back in the day. I still have a T-shirt that Lee Shepherd signed that has that car on it. That guy could sure drive, and he was a whiz at cylinder heads.
I have to say that even here in the desert of Southern California, I have yet to see a truck as solid as yours. That thing is amazing.
#15 |
The amazing part is the truck was built in Atlanta,and sold in in ga. to a fellow here in Alabama,where it stayed for the last 46 years and still looks that good.!!! I'm a lucky man.!!
Even swap the race as a roller (no motor or trans ) for the truck.Southern trucks should not be that nice.Only had 80.000 miles on it.drove it three weeks 120 miles,round trip with the a/c so cold had to keep it on low.!!! And yes the car was built as a Reher-Morrison Pro Stock Clone.
#16 |
60-66 Nut
I agree. That truck is unbelieveably clean.
Thanks for the engine build pics ![]()
#17 |
"Where were you in '62?"
![]() Join Date: Jul 2004
Nice...................
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#18 |
Made some good head way today,pulled the engine and trans,lifted the cab off the frame,and started cleaning and painting a few parts.
![]() Welded and filled the mirror hole's for the smooth body look. ![]() Cleaned and repainted upper and lower a arms,also removed bump stop and bracket on the lower. ![]() ![]() Gas tank looks good after 46 years .!! going back with under bad tank,another hole to weld and fill.!! ![]() Bare frame too be power washed and cleaned next week. ![]() Ordered my porterbuilt tubular trailing arms and cross member,Coil over shocks and tubular motor mounts.Going pull the rear end and have it cut 1/12 to 2 inches and start with the rear rebuild first.!! Making head way.!!!!! ![]()
#19 |
Seat still looks good after 46 years.!! May go back with 2001 chevy seats and console.
#20 |
Who Me?
Looking good!!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#21 |
Got it down to bare frame today,off to get it sand blasted next week.Ready to start building instead of tearing down.!!!
![]() ![]() ![]() Only thing in that pile, I will use is the rear end.! New porterbuilt trailing arms and cross member on the way,disc brakes, drop spindles,and some fresh control arms with drop springs.!! ![]()
#22 |
Great looking build Contagious102 definately following this one for sure. Was wondering what you're going to do with all your old parts that you're not reusing?
#23 |
That truck was in great shape, nice to start with something so good.
#24 |
I will try to sale and get all the left over stuff back in some body's truck.Good parts are to hard to come by.!!Thanks for all the nice comments.!!Hope to start building ,not tearing apart next week.
#25 |
Looking good!
