11-14-2012, 10:49 AM | #1 |
(2)22"x9 coys (2)20"x8.5 coys w/ toyos
I have 2-22x9" coys c5's satin finish and 2-20x8.5 coy c5's with 5"bs on both. They also have toyo proxes s/t tires with 95% tread left on them. I had them on my 71' c10 for street wheels, truck has since gotten way to wild for street use...track only now. $1400.00 purchaser pays for the ride.
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage Last edited by skeeterbug; 12-05-2012 at 10:10 AM. |
12-01-2012, 09:37 PM | #2 | |
Re: (2)22"x9 coys (2)20"x8.5 coys w/ toyos
Posted via Mobile Device |
12-01-2012, 09:48 PM | #3 |
67-72 parts collector,…
What size tires?
12-05-2012, 10:07 AM | #4 |
Toyo s/t Tires are 255/40 ZR20 front, and 265/40 ZR22 rear. I am not sure I do some where, will have to look tonight on home PC. The truck is here at my shop now with the fronts on but steelies w/ dot slicks on the rear. Here is one about 1 1/2 years ago while in rebuild stage.
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
12-05-2012, 10:45 AM | #5 |
Here it is today, i am trying to unload the coy wheels so I can purchase two 15x14 holeshot magnums w/ hoosier 31x17.5-15's and (2) champion Cap 5 15 x 6 w/ moroso ds/2 skinnies.
12-05-2012, 10:55 AM | #6 |
cap5 front wheel
12-05-2012, 10:58 AM | #7 |
holeshot revolver rear wheels
