Old 11-15-2012, 12:53 AM   #1
Davemotohead
Davemotohead's Avatar
Electric Heater Core Valve available?
The Vaccuum operated Valve on the pass fenderwell that lets hot water thru the Heater core,,is there an electric one available? Thanks.
Davemotohead is offline   Reply With Quote
Old 11-15-2012, 01:01 AM   #2
JORGIE95961
Re: Electric Heater Core Valve available?
that might get a little too hot for then plastic box
JORGIE95961 is offline   Reply With Quote
Old 11-15-2012, 01:15 AM   #3
Davemotohead
I am talking about the Vac operated valve that opens and lets the Hot water into the heater core,,I want to change from vac operated to electric operated valve?
Old 11-15-2012, 08:17 AM   #4
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Most of the aftermarket A/C companies sell a 12V servo hot water valve. Is that what you're looking for?
http://www.vintageair.com/2012catalo...Page%2074).pdf
Upper right hand corner
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 11-15-2012, 08:16 AM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Electric Heater Core Valve available?
Yes they are out there.
http://www.alibaba.com/showroom/12v-dc-water-valve.html
http://www.alibaba.com/product-gs/62...ally_Open.html
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-15-2012, 12:40 PM   #6
Davemotohead
Yes! thank you! From the looks of it buying the entire Vintageair kit is the way to go for A/C-Heat!
