Old 11-15-2012, 12:21 PM   #1
contagious102
contagious102's Avatar
Coil over rear end setups
Anybody have a few pics of a rear end set up with coil over shocks instead of coil springs.Thinking about running with Porterbuilt tubular trailing arms and using a coil over shock set up on my 66 step side.Would like to have it as low as i can go, but static drop instead of bags.Truck should see some track time and i think this would work well street or strip.Thoughts?
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 11-15-2012, 01:19 PM   #2
contagious102
Re: Coil over rear end setups
Just got through looking at your set up, 1Bad62Pro/Street .Great job.!!That upper bar bracket fits under the bed fine? and what rate springs did you go with on your coil overs,as mine is step side also.That turned out really nice.!!
Old 11-15-2012, 03:25 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Coil over rear end setups
Yep,
We had to make a few adjustments but she's fits fine.
The bed sits up a tad bit higher.
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
Competition Engineering #247-2051K7 Rear Coil-Over Shock Kit
250lb springs included.
3-way adjustable shocks
Upper mounts
Adjustable lower mounts (with 6" of ride height adjustment)
Vehicle weight is critical to suspension performance so choosing the correct spring rate based on rear end weight maximizes the suspension's ability to transfer weight and improve traction.
http://www.jegs.com/i/Competition+En...051K7/10002/-1
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 11-15-2012, 03:33 PM   #4
contagious102
Did you use the 250 lb springs on your set up.?
Old 11-15-2012, 03:44 PM   #5
1Bad62Pro/Street
Talking Re: Coil over rear end setups
Yes.
You have to drive it a while to let the springs set then adjust the as needed with a Spanner Wrench.
I love this setup!
http://www.competitionengineering.co...es/chassis.asp
