how to remove tranmission tunnel
1964 c10 - Is it a good idea to remove the transmission tunnel when replacing the clutch - How do you remvoe the darn thing?
1961 crewcab
Re: how to remove tranmission tunnel
some 64's the tunnel is spot welded in, if not pull the mat , and it might be bolted in, but, I think all the work you need to do is underneth the truck.
pull the flywheel cover unbolt the pressure plate , you will have to spin the motor to get them all unbolt the trans/driveshaft slide the trans back, or pull it out so you can drop the clutch and pressure plate out - if you have a floor shift trans, you can push down and spin the retainer ring around the shifter, to remove that and get it out of the way. thats kind of a quick explanation... hope that helps
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Thanks for the help - looks like mine is spot welded - I have a few questions regarding the cluthc / PP - 1.) should i remove the spak plugs to make it easier to turn the engine? 2.) What is the best way to get the pilot bearing out if I don't remove the bellhousing?
1961 crewcab
that would make it so that you could turn it easy by hand, sometimes there is a bolt holding the balancer to the crank, you can also use that to turn the motor.
not sure on the pilot bushing.. ? there might be enough room in there to use a tool to pull it out? hopefullu someone elese will chime in on removing the bushing....
HAte to interject here but...... I have changed clutch's in several car/truck combos. While recomended, I do not actually think the pilot bushing needs to be replaced except for enging overhaul. All it does is support the nose of the input shaft. It is not a cloce tolerance fit. I would give it a good visual and use best judgement from there. If you're leaving the BH attached then yes, remove the plugs! Why make a tough job tougher!?
If you must replace the PB. There is a tool made, available at most Parts houses. You insert it into the bushing then using a grease gun fill the cavity behind the bushing and hydraulically push out the bushing.... IF, you really must! Good luck on all!! |
Thanks for the confirmation - I really didn't feel like the PB needed to be replaced just because your replacing the clutch - I will give it at good look when I pull the clutch - but But since it is just supporting the end of transmission input shaft it should be ok (Hopefully)
