11-17-2012, 03:04 PM | #1 |
Quick bolt size question!!
What size are the nuts that hold rear lower shock mounts to the trailing arms/frame? Oart of the u bolt... They are extrenely large so I am trying to find out what size so I can go buy the appropriate wrench or socket. 70 c10 1/2 ton. Thanks!!
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 Last edited by dmw319; 11-17-2012 at 03:31 PM. |
11-17-2012, 04:33 PM | #2 |
Re: Quick bolt size question!!
my rear shocks mount with 3/4 inch nuts and bolts. although...i have a C30 and leaf springs...your C10 may be different
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
11-17-2012, 05:26 PM | #3 |
I found its 1 1/8. But I can't stinking break it loose! Tried a breaker bar and impact gun!
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
11-17-2012, 05:52 PM | #4 |
Let them soak over night with some good pent oil or warm them up with the heat wrench
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
11-17-2012, 07:29 PM | #5 |
11-17-2012, 06:47 PM | #6 |
Tried both! arghhhh
11-17-2012, 06:51 PM | #7 |
grind it off and replace it would be my next stop
72 C10 SWB Stepper 350/TH400 (might sell) 70 C10 SWB Stepper I6/4SPD (CURRENT PROJECT) 00 Silverado Rc 1500 2WD 5.3 09 Silverado Cc 5.3 2WD 4/6 DROP 04 Silverado ext 5.3 4WD |
11-17-2012, 09:12 PM | #8 |
Yep. Heat wrench, cheater bar, and patience should do the trick. If that fails split the nut. Use a cut-off wheel to cut a notch into the nut, being careful not to go too deep and damage the threads. Then use a chisel and hammer to open up the nut
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. Last edited by GRX; 11-17-2012 at 09:15 PM. Reason: because I can |
11-17-2012, 10:40 PM | #9 |
Thanks y'all. I think it's actually 1 1/16. Still can't get it off though!
11-18-2012, 04:32 PM | #10 |
If I do end up cutting the nuts/u-bolts, who sells them so that I can buy new ones?
11-18-2012, 05:50 PM | #11 |
way2low2 has them. hes on ebay and amember here.
http://stores.ebay.com/Street-Machin...p2047675.l2563
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
11-18-2012, 07:05 PM | #12 |
Thanks! Looks like his eBay store only has the lowering ones
I did end up cutting them so I will need some! Posted via Mobile Device
11-18-2012, 08:31 PM | #13 |
Talk to your local spring shop they can make them up in minutes
Fuzzy |
11-18-2012, 11:14 PM | #14 |
Hmm not sure I've ever been to a spring shop. Haha. Anyone else have any recommendations? Shouldn't a local parts store like Autozone or oreillys carry these in stock? Seems like 12 bolts are in so many vehicles they should..
11-19-2012, 12:23 AM | #15 |
Someone parting trucks on the parts board has to have them... Put up a WTB post
11-19-2012, 09:21 AM | #16 |
Actually just found that ECE carries them. Just bought a set!
11-19-2012, 09:27 AM | #17 |
Heat with torch and use a 1/2 impact to remove. I believe they are 1 1/16
11-19-2012, 09:34 AM | #18 | |
I will post some pics later. basically the nut was rusted solid to the ubolt and the ubolt was rusted solid to the inside of the trailing arms.
11-19-2012, 09:49 AM | #19 |
11-19-2012, 09:53 AM | #20 | |
They arent laughing anymore
11-20-2012, 10:15 AM | #21 |
